Ibanez 540R Radius neck removal - Jemsite
post #1 of 3 (permalink) Old 01-07-2015, 05:03 PM Thread Starter
Hi,
I've been offered a 540R, however the body is in a bad way so have been checking out the various 540 bodies on eBay. One thing that bothers me is the neck removal, without damaging the finish on the 4 neck retaining screws. Past experiences have tended to be with guitars that had the screws in VERY tight, and removal ended up marring the screw heads. Any tips on avoiding this?
Cheers,
Chris
chris101 is offline
post #2 of 3 (permalink) Old 01-11-2015, 01:14 PM
Re: Ibanez 540R Radius neck removal
If you are using the proper sized phillips head, that is not worn or damaged, then removing the screws should be pretty easy to do without damaging the screw heads. At least, that has been my experience.
aesthyrian is offline
post #3 of 3 (permalink) Old 01-11-2015, 02:58 PM
Yep, just make sure you have the right screw driver/ driver head . It is supper easy.
You may want a T driver to get more leverage. If you are comfortable using a drill, that is usually how I unscrew my necks.
j.arledge is offline
radius
RADIUS Neck dimensions, 540r vs 540rLTD mag8 All Other Guitars (including Prestige) 4 04-17-2014 10:50 AM
IBANEZ 540R HH RED RADIUS TECHNOROCKTRONIC Classified Ads: Guitars and Gear 0 11-04-2012 05:18 AM
FS: Ibanez 540R radius Viper neck Dr.StrangeNote Classified Ads: Guitars and Gear 1 11-20-2010 10:10 PM
FS: Ibanez 1990 540R LTD Radius 540R satchmo72 Classified Ads: Guitars and Gear 2 02-07-2010 10:04 PM
FS-Ibanez Radius 540R jem7vwh93 Classified Ads: Guitars and Gear 13 03-01-2005 01:41 PM
