Ibanez bolt on basswood/bolt on mahogany/neck through - Jemsite
post #1 of 3 (permalink) Old 05-12-2012, 03:09 PM Thread Starter
I can't decide between this combinations. Which is the difference between the bolt on and neck through mahogany, tone wise? Because I've read that the neck through predominates the brightness of the maple and is too much brighter than the bolt on. Don't know if it's true. Also I wanna know if basswood is better than mahogany for lead playing. I play mostly metal and rock (rhythm and lead).
KevinMarchesini is offline
post #2 of 3 (permalink) Old 05-12-2012, 03:57 PM
Reviews: 3
Re: Ibanez bolt on basswood/bolt on mahogany/neck through
If the neck thru has a maple neck, going through the body (where the bridge is), you won't hear the tone of the mahogany body "wings" as much as you would a full mahogany body with a bolt on neck. IMO, the neck thru will sound brighter, and the bolt on will sound warmer. Which tone is better for lead is up to you. I know lots of lead metal players that use both. If you use a high gain amp, lots of effects, or active pickups, it really won't matter that much..
leathermonkey7 is offline
post #3 of 3 (permalink) Old 05-12-2012, 08:19 PM Thread Starter
Is there a big difference between the bolt on mahogany and the maple neck through mahogany?
basswood body , bolt bolt-on neck , mahogany body , neck through
Bolt On vs Neck-Thru adil2552 Tech: Setup, Repairs and Mods 10 07-22-2011 11:03 PM
G&L 3-Bolt neck plates? ELicari All Other Guitars (including Prestige) 1 01-23-2008 08:49 PM
Bolt-on VS neck-thru hollow125 Ibanez JEM, UV, JS & Other Signature Models 17 06-09-2007 10:49 PM
New Neck-Through vs Bolt-On The_Grindfiend Tech: Setup, Repairs and Mods 22 09-06-2004 01:36 AM
Bolt-on neck adjustment Axefretters Tech: Setup, Repairs and Mods 6 12-17-2002 12:58 PM
