Ibanez Lo-Pro Edge Tuning Problem - Jemsite
post #1 of 16 (permalink) Old 06-24-2011, 06:54 PM Thread Starter
Hello everyone.
I've an awesome Ibanez RGR570IPT with the Lo-Pro Edge tremolo.
I read this is an awesome tremolo. This tremolo has been used by Vai too!
I've got some tuning problems. When I use the whammy bar, it goes out of tune, and the guitar go back in tune if I don't use the tremolo.
What can I do?
VexHead is offline
post #2 of 16 (permalink) Old 06-24-2011, 07:48 PM
Re: Ibanez Lo-Pro Edge Tuning Problem
There could be several reasons why it is not staying in tune. For one, if they're new strings, you gotta stretch the strings to relieve some slack out of them. Second, you need to make sure the strings are properly locked/clamped both at the nut and the trem. Another thing that could be causing this is a loose stud which you would probably have to get repaired at shop. Lastly, make sure the thing is setup properly. Use the following as a guide for proper setup:
Like I said, there are a # of reasons why its not staying in tune. Getting floating trems setup properly is a pretty detailed science, but once you get it it's pretty effing sweet. This is a start so I hope this helps!
Cory
cornstar70 is offline
post #3 of 16 (permalink) Old 06-24-2011, 08:01 PM
Reviews: 98
Are you stretching the strings? Is the guitar intonated correctly?
AlaskaBat is offline
post #4 of 16 (permalink) Old 07-02-2011, 06:17 PM
i have 2 lo pros one in a 770..the other in a 550..an i love them..best trem there is..try the link it will help you out alot on a proper set up...best of luck
pink13 is offline
post #5 of 16 (permalink) Old 07-02-2011, 06:23 PM Thread Starter
Hello.
Sorry if I didn't answer!
Yeah, i Stretched the strings and it is intonated correctly.
But I don't know what can I do! The Ibanez goes out of tune when I use the tremolo, but only when "bend the note". Sorry, but I don't know how to say it in english.
Mhh… It goes out of tune when I pull the tremolo upwards.
Understand?
I'm going to bring it to a lute maker…*
HEELP!
VexHead is offline
post #6 of 16 (permalink) Old 07-02-2011, 10:02 PM
We call that a "pull-up". Does it go back in tune if you do a dive (push it down) afterwards?
I think you need to sharpen your knife edges:
http://www.ibanezrules.com/tech/setup/sharpening.htm
just4kinks is offline
post #7 of 16 (permalink) Old 07-03-2011, 06:35 AM Thread Starter
Yes just4kinks, it goes back in tune if I push it down!
VexHead is offline
post #8 of 16 (permalink) Old 07-03-2011, 10:36 AM
Try replacing the trem studs and sharpening the knife edges.
Takin' a Ride is offline
post #9 of 16 (permalink) Old 07-03-2011, 12:58 PM
Reviews: 4
Here what you need to do.
1.) set the fine tuners to the middle,
2.) unlock the nut pads
3.) Dive the bar up and down a few times, always ending on a dive
4.) tune with the tuners on the headstock, not the fine tuners.
5.) repeat 3-4 a few times until the tuning settles.
6.) Re-lock nut, do some whammy stuff, if not in tune, start back at 2
7.) ???????????????????????
8.) profit.
read this before you do anything stupid (coughsharpentheknifeedgescough) http://www.ibanezrules.com/tech/setup/lockdown.htm
Good luck!
fwd0120 is offline
post #10 of 16 (permalink) Old 08-23-2011, 07:18 AM Thread Starter
I'm alive
Now I'm going to change the tongs (?)("molle" in italian) , and the locking nut. Also I'm going to sharp the edges.
Just a question: If, after the work, the guitar won't stay in tune? What can I do?
VexHead is offline
post #11 of 16 (permalink) Old 08-23-2011, 11:43 AM
Reviews: 98
Does it happen on all strings? Have you tried changing strings? Was the locknut bad? Why did you change it? My Italian is a bit rusty, so I don't remember "molle." Go to ibanez.com, or ibanezrulez.com and find the part name or number.
post #12 of 16 (permalink) Old 08-23-2011, 08:55 PM
RGTFanatic's Avatar
I guess I'll ask the obvious.....are the locking screws locked down???
RGTFanatic is offline
post #13 of 16 (permalink) Old 08-24-2011, 06:29 AM Thread Starter
Yes, with all strings.
I changed them with DR Tite Fit 9-46.
This is what I meant for "molle" http://www.webalice.it/gianlui/img/chitarra/molle.jpg
VexHead is offline
post #14 of 16 (permalink) Old 08-24-2011, 06:50 AM
Reviews: 98
Originally Posted by VexHead View Post
You've got 4 items in that cavity: Trem claw screws, trem claw, trem springs, and the trem block.
On a side note, I translated "molle." As a noun, it means "tongs." That gave me a first thought of the trem claw screws until I looked at the adjectives: soft, flabby, tender, weak, lax, squashy and feeble. Those are pretty strong arguments to indicate the trem springs.
Have you looked at the knife edges yet?
post #15 of 16 (permalink) Old 08-24-2011, 07:41 PM
RGTFanatic's Avatar
I'll ask again.......
Edge 3 Tuning problem!!! prydogga Tech: Setup, Repairs and Mods 30 06-26-2010 11:10 AM
Original Edge tuning stability problem Winter Tech: Setup, Repairs and Mods 8 06-08-2010 04:47 PM
Edge Pro Tuning Stability Problem TheYoungGuitarist Tech: Setup, Repairs and Mods 1 01-14-2009 10:10 PM
edge tuning problem..... caprile Tech: Setup, Repairs and Mods 3 05-24-2002 03:52 AM
edge tuning problem - edge tuning problem johank Tech: Setup, Repairs and Mods 1 10-03-2001 10:30 AM
