Ibanez Pickup Ring Swap - Jemsite
post #1 of 4 (permalink) Old 04-21-2012, 05:48 PM Thread Starter
KMT
Hi I have a S520ex and it has all balck hardware. I found some good deals on chrome color pickuprings but they come from an RG570. I've seen alot of RG rings that are advertised to fit certain models of S type bodies but mine is not on the list. Any one ever try to swap these or know if they will fit??
Thanks!
KMT is offline
post #2 of 4 (permalink) Old 04-21-2012, 10:30 PM
Re: Ibanez Pickup Ring Swap
If your rings are flat-bottom then I believe all you'd have to worry about is whether the holes line up. I've broken off toothpicks in the holes with superglue then redrilled to fit new rings, works great.
axel_f is offline
post #3 of 4 (permalink) Old 04-22-2012, 04:27 PM Thread Starter
KMT
Were the pickup rings from different countries? Also what was the difference in the holes? Just spaced further or misaligned?
KMT is offline
post #4 of 4 (permalink) Old 04-22-2012, 06:58 PM
The seller never listed what model they were from, they were brushed nickel finish, one flat piece of metal cut to shape unlike my original rg570 cosmo rings which were stamped or cast to be hallow on the backside with slightly curved tops. The holes were close but not enough that some screws didn't want to go in at an angle. $10 for the pair and a good base for paint, couldn't pass them up, and in the end I had to make them work somehow.
axel_f is offline
pickup ring s520 rg570
Pickup Ring replacement ermonski Tech: Setup, Repairs and Mods 7 11-28-2011 08:39 AM
Ibanez RG450DX Pickup Swap?? Help Ytsejam777 All Other Guitars (including Prestige) 0 11-20-2010 02:18 PM
Ibanez RGA 121 pickup swap riggawaggel All Other Guitars (including Prestige) 5 05-27-2010 03:47 PM
Ibanez ART300 pickup swap TonyG73 Pickups & wiring 0 04-22-2009 11:40 AM
Which Pickups??? - Pickup Swap on my Ibanez RG550EX MrNiceguy87 Gear, Equipment, Recording & Off Topic 15 04-27-2002 06:56 PM
