ibanez pro line - Jemsite
post #1 of 13 (permalink) Old 10-04-2010, 07:56 AM Thread Starter
ibanez pro line
i own an ibanez pro line 1770 . It has two switses . The second switch
is a push - pull and under it it seems that the pickguard is broken .
what can i do to change it ??? are there any pickguards in stock in ibanez ?
because making a new one is quite expensive ..
munchkin is offline
post #2 of 13 (permalink) Old 10-06-2010, 12:30 PM Thread Starter
Re: ibanez pro line
nobody ?????
munchkin is offline
post #3 of 13 (permalink) Old 10-06-2010, 12:42 PM
Reviews: 59
Re: ibanez pro line
Hard to say since it's an old model. Have you contacted Ibanez?
hp29 is offline
post #4 of 13 (permalink) Old 10-06-2010, 01:20 PM
Re: ibanez pro line
You either have a new one cut or you live with it.
Rich is offline
post #5 of 13 (permalink) Old 10-06-2010, 03:30 PM
stratoskier's Avatar
Re: ibanez pro line
I once had an old Roadstar with a similar problem. My hack solution was to glue another piece of pickguard-like plastic to the bottom of the pickguard (underneath the busted part), and then drill a hole through that for the shaft. That actually worked fine and the knob did a decent job of concealing the half-arsed fix. Depending on how pretty a repair you want, silly solutions like that often work. However, a ProLine 1770 is a very nice guitar and might deserve better.
Cheers,
Bert
stratoskier is offline
post #6 of 13 (permalink) Old 10-08-2010, 11:07 AM Thread Starter
Re: ibanez pro line
yes it might now that ive given some thought ..
i will try to contact the local ibanez dealer maybe they have a pickguard that fits ..
thanks guys .
munchkin is offline
post #7 of 13 (permalink) Old 10-08-2010, 11:21 AM Thread Starter
Re: ibanez pro line
and also another seems to be problem that i have is that i cant pull out the volume and tone knobs ...... no allen screw no nothing ....
this thing is driving me crazy !!!
does anyone have a proline ??
munchkin is offline
post #8 of 13 (permalink) Old 10-08-2010, 12:18 PM
jim777's Avatar
Re: ibanez pro line
I have a 2550, with the burled metal knobs, but it isn't in front of me. Don't they have screws into the sides of the knobs to loosen the knob from the shaft?
jim777 is offline
post #9 of 13 (permalink) Old 10-08-2010, 03:10 PM
Re: ibanez pro line
PL1770 should be standard knob-lift procedure. Devils fork, rag or whatever. Same thing as pulling Fender knobs.
danix is offline
post #10 of 13 (permalink) Old 10-09-2010, 02:52 AM Thread Starter
Re: ibanez pro line
ok i will try it ( again ) but there are no side screws no nothing on the knobs ..
munchkin is offline
post #11 of 13 (permalink) Old 10-09-2010, 04:56 AM
Reviews: 120
Re: ibanez pro line
Yeah, you need to put a cloth around the knob, and gently pry off with a flat-head screw driver or something. They are tight though.
LonePhantom is offline
post #12 of 13 (permalink) Old 10-17-2010, 07:38 AM
Re: ibanez pro line
Hey, it's been awhile since you posted this, but I see that someone in the Ibanez Collector's World Forum (http://www.ibanezcollectors.com/forum/) just listed three PL1770 pickguards for sale. They're black, gold, and textured silver. Check the "Free Classified" section over there if you're interested.
post #13 of 13 (permalink) Old 10-28-2010, 01:37 PM
Re: ibanez pro line
i made the pickguard myself cause i searched the internet for a new one but couldnt find one so i could pick my own colour now. it used to be the gold one on a yellow body. now it is black it is pretty. only i'm now stuck on the soldering.
D44n is offline
ibanez pro line
Ibanez 2011 Line-up? mattacuk All Other Guitars (including Prestige) 446 01-23-2011 12:25 PM
FS: Ibanez Pro Line 1660 PaHulkster Classified Ads: Guitars and Gear 1 02-21-2010 08:47 PM
WTB: Ibanez Pro Line PL2550 [UK] Dee Classified Ads: Guitars and Gear 1 07-08-2006 07:37 PM
Want to get a new 7 string... - Top of the line from Ibanez. BenoA Ibanez JEM, UV, JS & Other Signature Models 16 01-29-2002 09:05 PM
