Ibanez RG 550 bizzare neck - Jemsite
post #1 of 32 (permalink) Old 07-03-2012, 06:09 PM Thread Starter
Hallo everybody, i've been reading a lot here but just registered cause i got a question that bugs me abit.
I got an Ibanez RG 550 '97 RFR, and just mesured the neck's width. It is 41, not 43 mm. Basically there is not other problems, but this bugs me cause a frind's RG550 seems to be 43 mm, cause i just feel it wider and unfortunately more comfortable. So anyway can someone tell me if this is due to the year 1987 as i said or is it pretty common or not? Thanks again in advance!
Asstaroth is offline
post #2 of 32 (permalink) Old 07-03-2012, 06:29 PM
RGTFanatic's Avatar
Re: Ibanez RG 550 bizzare neck
Welcome to Jemsite Man!!!
How wide is your neck at the nut???
RGTFanatic is offline
post #3 of 32 (permalink) Old 07-03-2012, 06:48 PM Thread Starter
Well this is the nut width - 41mm and i read that it should be 43.
post #4 of 32 (permalink) Old 07-03-2012, 08:25 PM
usually maple neck are wider for rg550...yours must be rosewood
djanggo is offline
post #5 of 32 (permalink) Old 07-03-2012, 09:44 PM
Reviews: 120
Really? I find that hard to believe. Everything I've seen in writing (and with my own guitars) suggests that they are all 43mm, regardless of fretboard material. Where are you getting your information from?
LonePhantom is offline
post #6 of 32 (permalink) Old 07-03-2012, 11:58 PM
Because i have both 550s maple and rosewood....its a standard kind of thing.... Not ibanezfactory faulty....all 550s arelike that... Rosewood frets are closer and maple a bit wider frets
djanggo is offline
post #7 of 32 (permalink) Old 07-04-2012, 04:24 AM Thread Starter
Well it's maple, so... it is not that, maybe i should've said it earlier sorry for that, but i thought that fretboard material is not important for that, and i still do. Anyway i guess it's just a...misfortune
post #8 of 32 (permalink) Old 07-04-2012, 05:19 AM
Reviews: 6
That makes no sense because the necks are cut the same regardless of the fretboard material. There were some guitars produced in 97-98 that featured a 41mm width at the nut. I can think of a number of scenarios that could explain how your guitar ended like that, other than the possibility of a neck swap later down the road.
Did you pull the neck off and inspect the stamps in the neck pocket and neck? It may help shed some light on this.
Fender868 is offline
post #9 of 32 (permalink) Old 07-04-2012, 05:58 AM Thread Starter
No i haven't but I'm pretty sure of the guitar's origin and i know the previous few owners. Besides the neck is '87, no stamp only a sticker, and i don't think that there was a neck swap, and besides all that the color of the headstock is absolutely the same, you know faded, pinkish RFR. It's not a very big deal, but it's good to know that i'm not the only one. Thanks for the opinions, i'd be interested to see some more. At first i was disappointed but now i feel kinda special
post #10 of 32 (permalink) Old 07-04-2012, 06:04 AM
But i still feel my maple 550 wider abit then my rosewood 550
djanggo is offline
post #11 of 32 (permalink) Old 07-04-2012, 06:08 AM
Reviews: 98
Nope.
I just measured my 550R and 550M necks at the nut--both are 43mm.
AlaskaBat is offline
post #12 of 32 (permalink) Old 07-04-2012, 06:46 AM
Reviews: 120
They aren't...
post #13 of 32 (permalink) Old 07-04-2012, 08:05 AM
TWJ
rosewood shrink alittle overtime due to their larger open pores
TWJ is offline
post #14 of 32 (permalink) Old 07-04-2012, 08:31 AM
Reviews: 98
Then the fretboard would be narrower than the maple neck it's attached to....
Let's not forget that these same necks were used on all 500 series RGs. Why doesn't a rosewood fretboard on a 570 shrink? It's the same neck.
post #15 of 32 (permalink) Old 07-05-2012, 05:43 PM
I think That's not true. My ibanez rg 3120 has rosewood wtih wider neck.
VanHalen is offline
rg 550. neck. width
FS: LOCAL DEAL(MPLS MN)- Lot of Ibanez RG550 parts, neck, body and Roadstar neck CrossingStar Classified Ads: Guitars and Gear 3 06-10-2011 07:24 PM
fs Ibanez rgt42 body/neck neck thru no pup's or hardware gunkungfu Classified Ads: Guitars and Gear 5 09-15-2005 06:45 PM
ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only) 7-request Pickups & wiring 2 07-05-2005 11:18 AM
Bizzare Buzz... redseven69 Tech: Setup, Repairs and Mods 3 06-03-2005 08:16 PM
Bizzare Truss Rod Situation, Need Help! Triangle2 Tech: Setup, Repairs and Mods 16 03-10-2004 05:41 PM
