Ibanez RG350EX Made in Indonesia. - Jemsite
post #1 of 10 (permalink) Old 08-15-2007, 02:34 PM Thread Starter
hey guys,..well this is my first post to this forum,.on a really helpfull website,..so thanx for all who views my problem
newayz i just bought this RG350EX ,.which is the black one with a silver pickgaurd ,..i got it new,.for nearly $400. so i started playing on it when i got home ,.and i sometimes feel that the 8th fret on the B string kinda scratches the fret when i do bends or some hard vibrato. i don't know if this is normal :S,..
as am also scared that the guitar is defective. thing is i could clearly hear that scratchin sound cuz right now i got no amp so i sometimes play it unplugged ,...is that normal guys ,.or is the strings are too rough or what ?
please help,..
thanx
hamoksh is offline
post #2 of 10 (permalink) Old 08-15-2007, 02:41 PM
Re: Ibanez RG350EX Made in Indonesia.
You might just need a truss rod adjustment to fix the problem, or you might have a slightly high fret that needs to be filed. Those are my guesses from your description here.
ken_r152 is offline
post #3 of 10 (permalink) Old 08-15-2007, 02:49 PM Thread Starter
thanx for the quick reply man....but does a truss rod adjustment cause the strings to kinda scrape the fret like that ? ,.am just worried about that cuz i don't want my frets to be worn out,..cuz its still a brand new guitar,..and if the frets are killed ,..its done,..in egypt here there are no places really to do fret jobs n stuff
PS: and if one fret is a bit high,...it shouldnt make a difference IMHO cuz that sound is like as if the string is soo rough and its just scraping it,. IMO i thing the sound would still be there no matter how high the fret is,..or maybe that's just me ,.am really confused here :S
hamoksh is offline
post #4 of 10 (permalink) Old 08-15-2007, 03:33 PM
Reviews: 10
hamoksh - i got a 350 as well, u maybe able to just slightly raise the bridge (bottom screw on bridge that angles it up or down causing the strings to either raise or lower to the fretboard) try slighly adjusting that to see if buzz goes away. I had a similar issue on the A string around fret 3 or so and that cured it.
Quick and easy to do too, and if it doesnt work, then no harm done putting it back to where it was, then you could try one of the ideas mentioned above.
richard1973 is offline
post #5 of 10 (permalink) Old 08-15-2007, 06:29 PM Thread Starter
well,.richard thanx for the reply,..and i was basically trying to tune it today ,.
i kept tuning it and it kept going out of tune again,..i know this is a floyd thing,.so i kept doing it for some time ,.and i noticed the rear end of the bridge kinda tilting up,..away from the bodyy,..and it solved that scraping thing that used to happen considerably,..i think it has to do with the strings ,..
so if u don't mind my noob question lol,.as this is only my second floyd guitar,(other one was two years aago so am a bit rusty)... does the bridge have to FLAT ? ,.or is it ok to keep it tilted like that ?
thanx again guys
hamoksh is offline
post #6 of 10 (permalink) Old 08-15-2007, 06:37 PM
Reviews: 120
You should try and keep the knife edges of the bridge (the bits that move on the studs/trem posts) level with the top of your body for best tuning stability.
LonePhantom is offline
post #7 of 10 (permalink) Old 08-15-2007, 07:37 PM
thanx again guys
No, it doesn't have to be flat, however bridge sitting parallel with body seems to be the balance point where the bridge edges centre themselves against the pivots, and SHOULD stay in tune a little better - this setup also gives you an ideal combination of down and up trem range.
Generally the accepted approach to raising the action is to screw the bridge posts UP a little (counterclockwise, looking from above).
I don't think Ibanez level and dress the frets on Korean/Indonesian RGs, so unfortunately uneven, slightly rough frets are not uncommon (it's not a defect, it's just cost cutting!)
Cheers
David
David McCarroll is offline
post #8 of 10 (permalink) Old 08-16-2007, 06:15 PM
Raising the bridge will help...... but it sounds to me like the neck is at least bent.
Im not gonna tell ya how to adjust your trussrod. Thats gonna cause you more probs if you do it wrong. (no guarantee youll follow directions n such).
My advice.....
Take it to a "qualified" luthier and pay him 20 bux to make your axe behave.
An 350 isnt a bad instrument. Killer for newbs..... and a player with 20 yrs under his/her belt would like em too.
Tungus is offline
post #9 of 10 (permalink) Old 08-22-2007, 08:32 PM Thread Starter
Cheers
David
yea actually i do think ure right David. its kind of a really cheap guitar tho,...i got everything sorted out on my own ,.and now its all good again. and actually guys i was surprized as to how much the Edge III stays in tune. it can't offcourse be like the Edge pro or nething ,..but i do satch squeels ,.and dive bombs and kinda use the trem alot ,..and am surprized i haven't tuned it at all after i adjusted the bridge to be flat n all .,.
thankx guys for all the hlp,. great forum seriously,.
hamoksh is offline
post #10 of 10 (permalink) Old 08-23-2007, 12:14 AM
Dee
hamoksh -- take a look at the information here: http://www.ibanezrules.com/tech/setup/index.htm
Dee is offline
david mccarroll , rod adjustment , truss rod , truss rod adjustment
Leaving Ibanez guitars - No more jems for me jem7pbk Ibanez JEM, UV, JS & Other Signature Models 141 12-11-2010 07:16 PM
Fender Esprit... Made by Ibanez? Riddles All Other Guitars (including Prestige) 2 04-26-2007 02:08 PM
The new RG 350dx with a all maple neck Roadstar All Other Guitars (including Prestige) 25 01-28-2007 08:49 PM
FS: Made In Japan NOS Condition Ibanez SC420 S-Classic! Robotechnology Classified Ads: Guitars and Gear 1 07-24-2006 11:03 PM
WTB: a 7 string Japan made Ibanez! axechain Classified Ads: Guitars and Gear 11 07-09-2005 03:22 AM
