Ibanez RG550 neck into RG470 body? - Jemsite
post #1 of 12 (permalink) Old 10-09-2012, 05:44 AM Thread Starter
Exclamation Ibanez RG550 neck into RG470 body?
Is it possible to put a RG550 neck into a RG470 body? Both have square heel neck joint. Are the dimensions of the neck and body the same?
buldot is offline
post #2 of 12 (permalink) Old 10-09-2012, 06:50 PM
RGTFanatic's Avatar
Re: Ibanez RG550 neck into RG470 body?
Yes, it will work. The holes in the body for the neck screws will not line up properly with the holes in the neck, but that is very easily fixed.
RGTFanatic is offline
post #3 of 12 (permalink) Old 10-09-2012, 07:58 PM
Reviews: 120
If it's a square neck heel then they should match just fine. The early MIJ 470s used the same 550 necks.
LonePhantom is offline
post #4 of 12 (permalink) Old 10-10-2012, 10:39 AM Thread Starter
here are the photos:
the four screw holes are in the right place but the fretboard seems not actually in the right position as you can see in the photo. is it alright?
buldot is offline
post #5 of 12 (permalink) Old 10-10-2012, 01:26 PM
Looks like you need to push the neck all the way into the pocket then redrill the holes.
axel_f is offline
post #6 of 12 (permalink) Old 10-10-2012, 05:50 PM
Reviews: 120
Does the pickup ring sit against the fretboard end? From what I can see it should. String it up as a test and see if the guitar intonates correctly.
post #7 of 12 (permalink) Old 10-10-2012, 06:16 PM Thread Starter
the neck is pushed all the way.
buldot is offline
post #8 of 12 (permalink) Old 10-10-2012, 07:09 PM Thread Starter
I can't test it right now. I will defloyd it first and put a fixed bridge on it. hope the intonation is just fine.
buldot is offline
post #9 of 12 (permalink) Old 10-10-2012, 10:08 PM
Reviews: 120
You can see where the paint colour has changed around where the pickup rings go. Does that line go up to where the neck end sits?
post #10 of 12 (permalink) Old 10-12-2012, 03:44 AM Thread Starter
Thanks man! I think I figured it out. The space is for the pickup ring.
buldot is offline
post #11 of 12 (permalink) Old 10-12-2012, 05:05 AM
Reviews: 120
Yep, should be all good then.
post #12 of 12 (permalink) Old 10-13-2012, 10:56 PM Thread Starter
thanks mate! I will post some pictures when it's finished.
buldot is offline
rg470 , rg550
rg550 body, neck , and more 200.00 andrewsfury Classified Ads: Guitars and Gear 6 06-20-2011 10:33 PM
FS: LOCAL DEAL(MPLS MN)- Lot of Ibanez RG550 parts, neck, body and Roadstar neck CrossingStar Classified Ads: Guitars and Gear 3 06-10-2011 07:24 PM
FS- Ibanez RG2610 Prestige Neck w/ Free RG550 Body!!!! C.Thep Classified Ads: Guitars and Gear 2 01-03-2011 11:01 PM
Will an rg470 neck fit on my rg570ex body? Secrets of Steel Tech: Setup, Repairs and Mods 1 09-03-2009 03:41 AM
FS RG550 body & neck, RG570 neck & misc screamndemon69 Classified Ads: Guitars and Gear 1 05-07-2005 12:58 PM
