Ibanez RG550DX versions - Jemsite
post #1 of 35 (permalink) Old 05-18-2013, 07:55 AM Thread Starter
I'm just trying to sort out how many different RG550DXs that exist..
I know of:
RG550DX LB - Laser Blue
RG550DX PN - Purple Neon
(RG550DX EG - Emerald Green??)
And then somewhere I remember reading that the *RG550 EG - Emerald Green* also is a DX becuase it's got cosmo black hardware and a green (color matching..) pickguard, which seems to add up, but that's the question I've got.. Is the EG a DX?
And are there others?
IbanezFanatic777 is offline
post #2 of 35 (permalink) Old 05-18-2013, 07:38 PM
Re: Ibanez RG550DX versions
AFAIK only the 2 that you mentioned, PN and LB. Any 550 EG model that you see with a matching scratchplate is an aftermarket job and just an RG550EG with the standard black scartchplate replaced. The only green RG550 that had a matching scratchplate was the RG550 serpent model and that had the serpent inlay on the maple fretboard.
IbanezDaemon is offline
post #3 of 35 (permalink) Old 05-19-2013, 12:51 AM
There are also the RG500 models which are basically the same as the 550DX....with exception of the color matched inlays.
edit--and don't forget the RG550LTD. These also had the matching color mirrored pickguards, but sported rosewood boards and sharks tooth inlays. Thete were PN and BK versions--and came out in 1994.
GodzillaPopcicle is offline
post #4 of 35 (permalink) Old 05-19-2013, 02:23 AM Thread Starter
Ok, so the EG with color-matching pickguard is not a DX
Actually there were 2 green RGs with mirror pickguard, and I think the pickguard both were gold..
#1 - RG5000SG - (Which people think makes Serpent Green. The green RG5000 which is the same color as the one with serpent inlay. Color-matching dot inlays.. Mable fretboard
#2 - RG Serpent - which has the serpent inlay on maple fretboard..
post #5 of 35 (permalink) Old 05-19-2013, 02:29 AM
There was never a green RG550DX
post #6 of 35 (permalink) Old 05-19-2013, 02:35 AM Thread Starter
@GodzillaPopcicle
"There are also the RG500 models which are basically the same as the 550DX....with exception of the color matched inlays."
- Yes, RG5000 has color-matched dot inlays. They were like the RG550DX, I figured too, great to get a confirmation they are.. The RG5000DY don't have matching dots, so except for the knobs (and tip?) and the pickguard, I can't see anything that does not scream regular DY..
"edit--and don't forget the RG550LTD. These also had the matching color mirrored pickguards, but sported rosewood boards and sharks tooth inlays. Thete were PN and BK versions--and came out in 1994."
- I know about the RG550LTD, there are 3 or 4 colors of these..
PN, BK, some gray-ish color and I think there are one more. I did not count these in as they don't fit my criteria of RG550DX (maple board..) though they have color-matching mirror pickguard (at least the PN does.. If not the pics I've seen of RG550LTD PN the pickguard may be aftermarket..)
So the ones that are DX
RG550DX-LB, RG550DX-PN
LB - Laser Blue
PN - Purple Neon
And the ones that may count
RG5000-RR, RG5000-LB, RG5000-SG, RG5000-PN (RG5000-DY)
RG Serpent
RR - Ruby Red
LB - Laser Blue
SG - Serpent Green (Also the Serpent-inlay one)
PN - Purple Neon
DY - Desert Yellow
And then the LTDs
RG550LTD-PN, RG550LTD-BK, RG550LTD-DAB, RG550LTD-NPM (RG550LTD-PWT?)
PN - Purple Neon
BK - Black
DAB - Dark Adriatic Blue?
NPM - New Penny (Metallic?)
PWT? - Pewter (Gray-ish)
And of course all the other *regular* RG550s
post #7 of 35 (permalink) Old 05-19-2013, 02:42 AM
Yes--the 550LTD PN has the purple mirrored pickguard.
after reading your replies--are you on the hunt for a DX?
post #8 of 35 (permalink) Old 05-19-2013, 03:15 AM Thread Starter
I am looking for a nice condition RG550DX
Why do you ask? :P
I've got serious GAS for many of these great instruments..
post #9 of 35 (permalink) Old 05-19-2013, 10:36 AM
I'll keep my eye out for one!
post #10 of 35 (permalink) Old 05-19-2013, 10:40 AM Thread Starter
Thank you, GP
post #11 of 35 (permalink) Old 05-19-2013, 11:18 AM
Originally Posted by IbanezFanatic777 View Post
Thank you, GP
You're welcome!
I'll send links to all I find. Keep an eye on your PM box...
post #12 of 35 (permalink) Old 08-09-2013, 07:00 AM Thread Starter
Just stumbled across this listing on 3bay - http://www.ebay.com/itm/ORIGINAL-Vin...item1e7e13f5dc
It's an Ibanez RG550(DX) - EG, which has got a green mirror pickguard and *all the finest hardware available at the time it was made*.. So, it's a DX which originally came with mirror pickguard afterall?
I'm asking because the seller claims it's all original, and I think he would have mentioned the change of pickguard if it was ever changed..? Maybe not, but it just made me wonder all over again about the emerald green one..
I'm sorry if it's illegal to post listings like that, but I just did it to get definite proff whether it came with a mirror pickguard or not, because, as I wrote above, the seller claims it to be all original, and does not mention the pickguard..
post #13 of 35 (permalink) Old 08-12-2013, 01:48 PM
Can't be a DX. Read the sellers description then have a look at the serial number. That's a 1990 serial number on that neck, yet the seller claims it's a 1993 model.
post #14 of 35 (permalink) Old 08-12-2013, 06:24 PM
Just had another quick look at the auction you posted, the headstock has been refinished at some point, doesn't really match the green on the body and the position of the logo is way off.
post #15 of 35 (permalink) Old 08-12-2013, 09:53 PM
It's weird that you mention that ebay guitar, because I bought one similar to it in 1995.
I'm pretty sure the serial on the neck was from 1992, but I've since swapped necks as the truss rod was messed up. I can assure you the headstock matched the body paint, but I don't know if the pickguard and knobs were aftermarket.
This is the pic of what it originally looked like when I bought it.
And, now that I actually dug some more, I found this:
http://s93105080.onlinehome.us/Ibane...og/1992/26.jpg
EG is one of the finishes listed under the RG550DX. So, is it a DX or not?
neubywankaneuby is offline
rg550dx
FS: 1992 Ibanez RG550DX Laser Blue muttznmongrelz Classified Ads: Guitars and Gear 9 09-07-2012 12:54 PM
Ibanez RG550DX PN ('92) shreddingjoris All Other Guitars (including Prestige) 4 03-11-2012 05:51 PM
Ibanez Vai Euphoria EP10P and other Versions sebastian All Other Guitars (including Prestige) 0 01-29-2012 07:46 AM
FS: Ibanez RG560, RG550DX for $300 each Severinsteelsmith Classified Ads: Guitars and Gear 4 01-19-2011 08:47 PM
My first Ibanez. :) - RG550DX Purple Neon. Phwoar! zoob All Other Guitars (including Prestige) 8 11-15-2001 09:21 PM
