Ibanez S420. bridge post wobble in the ZR trem, fix? - Jemsite
post #1 of 5 (permalink) Old 05-29-2015, 07:54 PM Thread Starter
Question Ibanez S420. bridge post wobble in the ZR trem, fix?
When putting my S420 back together after its refinish I noticed that the bridge mounting posts have a slight wobble to them when they are screwed into the body's inserts. Is this a problem? the guitar seems to stay in tune fine though.
Sc0rch is offline
post #2 of 5 (permalink) Old 05-30-2015, 03:44 PM
Re: Ibanez S420. bridge post wobble in the ZR trem, fix?
It's just normal for an non-locking stud to wobble. If you have an complex over it, drill and tap them for an set screw.
Eskil is offline
post #3 of 5 (permalink) Old 05-30-2015, 06:16 PM Thread Starter
reason I was worried about it was the ones that come with an original floyd rose have a tighter tolerance to them, they hardly wobble at all compared to the ibanez posts.
Sc0rch is offline
post #4 of 5 (permalink) Old 05-31-2015, 11:35 AM Thread Starter
easier said than done, there is no "set screw" in existence for a ZR trem. The ZR trem sits on it, not balances itself on a v-shaped knife point like the Edge trems.
Sc0rch is offline
post #5 of 5 (permalink) Old 05-31-2015, 03:25 PM
I know there isn't any original stud for ZR trem with set screw... All the anchor screws wobble if they aren't locked. Even thou FR studs wobble less for some reason but they're aren't locking. So they will wobble, but Ibanez locking studs won't =)
For a Knife trem the locking studs makes a big difference. But for the ZR perhaps it would make a bit difference but Ibanez settled it would be fine without.
So just go on with what you have
or
if you really want it to be locking...
Put the posts in a lathe and drill and tap them
Eskil is offline
What are these? Fell out of Ibanez S420 with ZR trem chilln2music All Other Guitars (including Prestige) 7 01-14-2012 01:47 AM
Edge arm holder wobble TheFreak777 Tech: Setup, Repairs and Mods 8 08-24-2011 10:34 AM
Ibanez SA160QM Trem post distance?? NickCormier All Other Guitars (including Prestige) 7 05-07-2008 09:35 AM
WTB: IBANEZ 2LE2-B Trem Post LennyX Classified Ads: Guitars and Gear 0 03-31-2008 07:10 PM
Need an ibanez trem post j.arledge Classified Ads: Guitars and Gear 3 11-24-2005 12:27 AM
