Ibanez sabre loaded with graphtech ghost midi - Jemsite
post #1 of 11 (permalink) Old 02-11-2013, 05:04 AM Thread Starter
Hi all, I have been modifying this ibanez s for a mate. It utilizes a graphtech ghost system. The midi jack was installed into the original guitar jack spot and a new jack was fitted to the rear. It had to be done like this because there was no where else i could fit it. The main board sits under the strings in a cavity where all the saddle piezios meet, midi jack,volume and quick switch. The original ibanez 5way switch cover has been changed to accommodate 2 mini switches. Being such a thin guitar i was really nervous doing the routing especially on the guitar jack.
Dimarzio fred bridge and air norton neck. 2 volumes/neck has push pull coil tap and a 3way switch
Midi ghost system has 1 volume and program patch up/down switch.
hapm gotoh tuners
Graphtech floyd rose
Note: my friend changed his mind half way into the project and decided he didn't want the acoustic phonic in conjunction with the midi. So thats why there is a unused battery boy and 3rd free micro switch spot. Also i still have to clip down the ribbon cable in the back cavity.
P.s i know not everyone likes midi guitars.
[IMG] [/IMG]
kramersteen is offline
post #2 of 11 (permalink) Old 02-11-2013, 03:08 PM Thread Starter
Re: Ibanez sabre loaded with graphtech ghost midi
bump, Not one reply? What a joke i thought all you guys where ibanez fans???
post #3 of 11 (permalink) Old 02-11-2013, 04:56 PM
Reviews: 120
If everyone else is like me I think we're just speechless! That's a lot of stuff shoved into an S. Good work, I hope it gives your friend the sounds they want.
LonePhantom is offline
post #4 of 11 (permalink) Old 02-11-2013, 05:18 PM Thread Starter
We could have picked a way better guitar to do it to in relation to the size of the sabre. It was a lot to fit into it. Thanks for the sympathy reply haha
This is another s i found with a similar setup, if you think mine is tight look at this...https://www.google.com.au/search?q=i...2F%3B640%3B480
post #5 of 11 (permalink) Old 02-11-2013, 05:43 PM
wow! I didn't even notice the cover in between the pickups at 1st. That thing is rad! Great job!
GUITARMAGEDDON is offline
post #6 of 11 (permalink) Old 02-11-2013, 06:14 PM
Well done many. Fairly technical upgrades especially for an 'S'. Bets it'll sound like no other!
Nick 6 is offline
post #7 of 11 (permalink) Old 02-11-2013, 08:29 PM Thread Starter
Thanks it is
post #8 of 11 (permalink) Old 02-12-2013, 08:58 AM
To be honest I don't care much for the s-series. But your work is really impressive, Nice!!
B.B.A. is offline
post #9 of 11 (permalink) Old 02-12-2013, 03:02 PM Thread Starter
Thanks for the kind words. The s series is a unique instrument i can understand why people would be a bit skeptical.
post #10 of 11 (permalink) Old 02-13-2013, 09:38 AM
Yikes - that's one heck of a thin body to cram all of that stuff in! As a hex guitar person myself I applaud your ingenuity in getting that all in there.
I think that's the first S I've seen with piezo/hex-out. I've seen tons of RGs and lots of other thicker bodied Ibanez guitars with that kind of capability but the S is so thin few dare to do it!
Suggestion: put a fake humbucker instead of the cover in that center position. I know that there are ways to get the hardware.....it would just be a facade but nobody would ever guess it's fully borged out!
Very cool! For my own instruments I didn't dare go that far since I wanted to be able to go back to stock if I had to:
The hardest part was moving the entire bridge pickup, pickup ring and everything north about 2-3 millimeters and still keep it stock looking so there would be room for the hex pickup to fit between the bridge and bridge pickup and still be able to use the Floyd Rose fully (up/down).
aliensporebomb is offline
post #11 of 11 (permalink) Old 02-13-2013, 03:17 PM Thread Starter
[quote=aliensporebomb;1224659] Suggestion: put a fake humbucker instead of the cover in that center position. I know that there are ways to get the hardware.....it would just be a facade but nobody would ever guess it's fully borged out!
You mean like this ibanez s i own?
Its not my guitar so i couldn't care less about the cover plate. plus i have actually grown to like it. Thanks for the reply tho, its good to see someone that respects the challenge i had on this. I mostly posted it up so other people wanting to do the same to sabre can see some solution's if they decide to do the same mods
ibanez sabre
Anyone using a Graphtech Ghost System for midi access... Dominik Hardy All Other Guitars (including Prestige) 4 01-31-2013 10:47 AM
Graphtech Ghost LB63 Bridge any good? enb141 Tech: Setup, Repairs and Mods 3 01-15-2011 02:15 PM
Graphtech Ghost Floyd System satchbo Gear, Equipment, Recording & Off Topic 13 05-01-2008 11:20 AM
Graphtech Ghost install - RG7421 Algiman Tech: Setup, Repairs and Mods 18 03-03-2008 11:29 AM
L.R. Baggs X-bridge or GraphTech Ghost Devo Gear, Equipment, Recording & Off Topic 0 06-20-2005 11:54 AM
