I'm gonna make a Double Neck! - Jemsite
post #1 of 6 (permalink) Old 07-09-2002, 10:58 PM Thread Starter
Hey, I have decided to make a double neck guitar out of two of the ones i already have. A Jackson and a kramer. Will this be hard? If its to hard i'd like ot know of a double neck i can get for around 200. im scared!!!
Merlin88 is offline
post #2 of 6 (permalink) Old 07-10-2002, 10:27 AM
Prepare for ALOT of work. Measure three times to cut once. Patience is everything. Even with the best tools and facilities, it will take days to finish the body.
You will need plenty of material to fill in the bottom of the body. Since both of the guitars are "Strat" shaped, the bottom contours (where the strap buttons are) won't line up flush. It will look like a rounded "W". You will need to fill this in with poly (or something similar), to make it flush. You will have to do ALOT of sanding to get everything smooth and even.
Not to mention, the wiring may be difficult, depending what you want.
I'd say look for a used Epiphone, Carlo Robelli, Rogue, Cort, Galveston, or something like that. It will satisfy your double neck craving and not kill your wallet (not to mention frazzle your nerves).
Cheers,
Butch
butch is offline
post #3 of 6 (permalink) Old 07-10-2002, 10:32 PM Thread Starter
alright, im scared.. Would it be any eayser with two vee shaped bodys?
Merlin88 is offline
post #4 of 6 (permalink) Old 07-11-2002, 12:42 AM
I would suggest measure up from the 2 bodies you have, and build yourself a new body rather than mess with existing ones, that is very doable, and you don't risk wrecking 2 guitars, you mess up your new body, you can still put together your 2 guitars again, you mess up your existing bodie's you're out 2 guitars.
littlegreenman is offline
post #5 of 6 (permalink) Old 07-13-2002, 08:44 PM
Warmoth sell doubleneck bodies
Strat and tele types is I'm not mistaken
Pablo is offline
post #6 of 6 (permalink) Old 07-14-2002, 12:06 PM
Even thought the Jackmer (or Kramson) concept sounds intriguing, I vote with the others here for the construction or purchase of a doubleneck body/guitar.
Greg
gkelm is offline
double neck , strap button , strap buttons
Jem double neck!!! UV-7-BK Ibanez JEM, UV, JS & Other Signature Models 6 01-16-2012 06:26 PM
Double Neck prydogga All Other Guitars (including Prestige) 4 08-07-2009 08:21 AM
2200$? Im gonna have to make my own... sl_tater Ibanez JEM, UV, JS & Other Signature Models 5 11-01-2007 11:05 PM
building a cab from scratch, need info - im gonna make a bog shawn Gear, Equipment, Recording & Off Topic 3 03-22-2001 03:55 PM
RG neck mod - Is this neck gonna fit? mikek Tech: Setup, Repairs and Mods 5 01-18-2001 04:07 AM
