install Stud inserts for edge trem - Jemsite
post #1 of 11 (permalink) Old 01-24-2010, 12:22 PM Thread Starter
how do i install stud inserts on a new unfinished rg 570 body for an edge? Do you use glue?
Also should i make holes for the strap and pickups pre-post laquering? does it make a difference?
/thx
ibanguitar is offline
post #2 of 11 (permalink) Old 01-24-2010, 05:10 PM
Re: install Stud inserts for edge trem
Stud inserts should be press fit. I would definitely drill the holes before you paint the guitar, and then I would CAREFULLY re-drill the hole after finishing just to clear paint out of the hole. This will help the paint from cracking around the hole when you drive the screw in.
TAorama is offline
post #3 of 11 (permalink) Old 01-25-2010, 11:43 PM
Ayrton's Avatar
Inserts go in BEFORE paint, not after.
The hole should be 7/16" if I remember correctly, and you don't want it so tight it cracks the body when you drive them in. I personally like them to be just snug with a touch of yellow wood glue.
Ayrton is offline
post #4 of 11 (permalink) Old 02-07-2010, 11:30 AM
Yes. All these people on the Bay stripping bodies and selling them without inserts have ruined the bodies. I once asked one of the big sellers(the guy with the overpriced shipping) how he got the inserts out. He said he screwed the studs down into the inserts and then yanked as hard as he could back in forth with the claw end of a hammer. You end up with wallered out holes, split wood, etc. You will never get those studs to stay in the holes again correctly. They will move around and lift.
OliverKlohzoff is offline
post #5 of 11 (permalink) Old 04-06-2010, 12:44 PM
Reviews: 21
sigh, I'm in the same position
I've got a painted 750 RG body with no stud inserts
I've bought a new lo-pro edge and I need to get the stud inserts in... they are far too wide to fit.
For a brief moment I considered hammering them in then realised how damn stupid that would be. So they're seriously meant to be a hand push fit?
In that case I have no idea what I'm going to do, drill the holes out wider I'd imagine.
I'm a bit pissed off if I'm honest.
D1m3b4g2 is offline
post #6 of 11 (permalink) Old 04-06-2010, 05:10 PM
What I have done,and I don't claim to be a expert is get a screw that fits the insert thread, put it in the insert and use a drill press to press the insert in. A towel on the drill press table works for a pad. Of course the hole in the body needs to be just the right size.
moonlight is offline
post #7 of 11 (permalink) Old 04-07-2010, 12:26 PM
Reviews: 21
I'm gonna buy some drill bits and scoop out the extra layers of paint that have gone down the holes. I'll try with a hand press/twist at first and if that doesnt work i'll drill the buggers out.
It's a clear 1mm misfit, which I appreciate sounds like nothing at all but there is no damn way I'm going to be able to force the pegs into a hole with that lack of clearance. It'll only compact the paint down further into the hole and potentially put a lot of strain onto the body. I don't want to crack it when I could just drill it out
D1m3b4g2 is offline
post #8 of 11 (permalink) Old 04-07-2010, 06:19 PM
press fit does NOT mean that you dont have to use a little whack with a hammer to make it seat in place....
we press fit femoral stems in bone and we have to whack the **** out of it.
scottop1972 is offline
post #9 of 11 (permalink) Old 04-11-2010, 09:01 AM
Reviews: 21
Ah ok, good. I did mine yesterday.
I drilled out to 11mm which is very nearly 7/16 imperial.
I had to use a hammer to get the stud bolts in but they went in fine with a few smacks.
D1m3b4g2 is offline
post #10 of 11 (permalink) Old 04-12-2010, 09:51 AM
Reviews: 12
the perfect drill for that is a Milwaukie 27/64 th it is a we over 10.7 mm and I believe the anchors ar about 11mm. I used that bit when I went from single locking POS trem and upgraded to a edge with locking posts and anchors
spudler_t is offline
post #11 of 11 (permalink) Old 08-08-2019, 01:00 PM
Thanks for the info, building a Jem and this answer was the 1st to pop up!!!
bammbamm is offline
stud insert inserts
WTB: Locking nut pad, stud inserts etc.. sirshredsalot Classified Ads: Guitars and Gear 6 11-15-2009 04:19 PM
WTB: Edge Stud Anchors/Inserts littlephil Classified Ads: Guitars and Gear 4 01-25-2009 08:43 PM
Any experience installing stud inserts? djrjems Tech: Setup, Repairs and Mods 7 05-18-2008 09:22 PM
i need just edge3 stud inserts -Rhaab Tech: Setup, Repairs and Mods 3 03-23-2007 01:03 AM
problem with my stud inserts!Help jemke Tech: Setup, Repairs and Mods 15 11-21-2002 10:18 AM
