Intonation problem with Edge-Zero II bridge w/ZPS3Fe - Jemsite
post #1 of 3 (permalink) Old 12-26-2013, 04:51 PM Thread Starter
i am having trouble with the intonation of the G and B strings on my ibanez. i havnt touched anything yet, but do i just release the neck lock-downs and take pressure off my strings, then undo the saddle screw and move the saddle to try acheive my intonation?
im confused, never attempted this before. cheers
hazlo is offline
post #2 of 3 (permalink) Old 12-26-2013, 06:34 PM
RGTFanatic's Avatar
Re: Intonation problem with Edge-Zero II bridge w/ZPS3Fe
The way your describing will work just fine.
You can also use a clamp to hold the bar in the dive position. this will slack the strings enough to make an adjustment......... it's easier and faster to re-tune afterward. Put some cloth between the body and the bar to avoid putting a dent in the paint.
RGTFanatic is offline
post #3 of 3 (permalink) Old 12-27-2013, 03:11 AM Thread Starter
awesome cheers for the advice ill let you know my progress.
hazlo is offline
edge zero 2 , ibanez , intonation
Jem 7v intonation problem jgparker Ibanez JEM, UV, JS & Other Signature Models 17 02-08-2015 03:18 PM
Edge Pro bridge problem: About that ring inside the tremolo hole rye715 Tech: Setup, Repairs and Mods 5 04-08-2013 01:30 AM
A problem with '89 FP intonation. Ad_Astra Tech: Setup, Repairs and Mods 12 09-27-2007 02:15 AM
Serious trem. angle problem with Edge bridge anonymousrg Tech: Setup, Repairs and Mods 2 01-23-2005 05:55 PM
JS (Edge Bridge) Intonation saTa Ibanez JEM, UV, JS & Other Signature Models 2 08-22-2003 08:21 AM
