J custom RG20136 saddle position question - Jemsite
post #1 of 2 (permalink) Old 06-11-2014, 07:38 PM Thread Starter
So I just got this guitar and am currently setting up the bridge. I have it intonated and noticed the saddle position to be similar to the cursed Jem7v. Basically with the jem7v the low e saddle was out of position to the sequence. It seems like a correct bridge should be in steps. Rich emailed me a pic and as soon as I looked at my Jem I knew I had the bad one. So now I'm here with a j custom and it seems like I may have the same issue. I can hear a pulsating noise over the 15th fret and up on the low e just like I did with the jem7v. My iron label rg fixed bridge does not have this issue and I'm using the sound of it to reference.
lorper is offline
post #2 of 2 (permalink) Old 06-19-2014, 04:54 PM Thread Starter
Re: J custom RG20136 saddle position question
So after looking through this more I figured out the proper intonation... ****ty batteries was causing it to read wrong so I got it intonation and setup pretty good. Only problem I was having was after diving the bridge it wouldn't return to zero but if I pulled up than it would go right back into pitch. I figured I'd let my tech take a look at it and he said he got it a bit better bit still having the same issue. Are these edge zero bridges k own for this by any chance? Does anyone have any tips on what to check?
lorper is offline
newbie saddle adjustment question dehanson1 Tech: Setup, Repairs and Mods 4 01-21-2012 10:56 AM
Lost roller on saddle - SAS32FM with SAT PRO Tremolo - Can I use SAT PROII Saddle? keykeeper Tech: Setup, Repairs and Mods 0 09-27-2010 05:53 PM
Swirl question - color wont stay in position nafigator Tech: Setup, Repairs and Mods 0 07-03-2009 04:46 AM
Could i change the 2 position switch of my RG620x to a 3 position switch? supergirl20_06 Tech: Setup, Repairs and Mods 4 05-10-2007 04:27 AM
RG620x could i change the 2 position switch to a 3 position switch without any mod? supergirl20_06 Pickups & wiring 6 04-25-2007 06:12 AM
