J Custom RG8570Z Neck Question - Jemsite
post #1 of 16 (permalink) Old 07-27-2017, 01:46 AM Thread Starter
Hey everyone!
I just got a used J Custom RG8570Z (2010) and I absolutely love it but one sort of odd thing is the neck between the 15th-24th fret feels a bit rough and unfinished, quite noticabelyu compared to the rest of the neck. Is this on purpose for grip or something or has the finish worn off? If so is it a problem?
Thanks!
Opendome is offline
post #2 of 16 (permalink) Old 07-28-2017, 03:00 PM Thread Starter
Re: J Custom RG8570Z Neck Question
and as a J Custom youd think the neck finish would be top notch? Also heres the listing of where I got it from, now Im kind of worried it might be a fake? It all looks legit though. THe buyer said he received the guitar straight from Japan without a case , certificate, Ibanez booklet though too which is odd.
https://reverb.com/ca/item/5350749-2...black-dimarzio
Opendome is offline
post #3 of 16 (permalink) Old 07-28-2017, 03:34 PM
site founder 0% owner
jemsite's Avatar
Another "round fret" moronically pedantic listing. Ugh. Priced high... check... meh trem... check... very rough shape for a JC.... yup! But it has ROUND FRETS!!!! Anyways... it's real and no certificate would be expected.
I wouldn't. But in fairness wood absorbs finish non-uniformly.
jemsite is offline
post #4 of 16 (permalink) Old 07-28-2017, 04:56 PM
A-holes really know how to make somebody happy they bought a great guitar for a good price......
From the pictures the neck finish looks fine, unless you have a close up? Otherwise, are you sure you're not feeling the grain in the walnut fillets? That's usually what everybody feels and thinks is something more complicated.
Rich is offline
post #5 of 16 (permalink) Old 07-31-2017, 02:47 PM Thread Starter
Hello!
I got it for $1400 USD is that still too high do you think? Most of the neck feels great but right on the heel of the neck it feels rough almost like theres no finish on it at all, should I get some 0000 steel wool at give it a rub? Its the maple itself. Im just worried about moisture and what not on the part of the neck that feels unfinished haha.
Also Im worried that he might of adjusted the action wit the studs locked, if it was forced would that be a problem and could it damage something? I tried putting a 2mm and a 1.5mm allen key into the studs but I dont feel them grab anything but when I tried to adjust the stud it wouldn't budge (as soon as I felt some good resistance I stopped as to not force it) with the same amount of force on my other RGs so I thjink the locks are still in there?
Thanks!
Opendome is offline
post #6 of 16 (permalink) Old 07-31-2017, 03:00 PM
The price is fine and in line with condition.
You will not unlock the sets [2mm] without backing the stud off first [3mm]. Just as after it's adjusted you want to tighten the stud down on the sets to take all the slop out of the threads.
if you're sure it's bare maple then 0000 will smooth it out.
Rich is offline
post #7 of 16 (permalink) Old 07-31-2017, 03:05 PM
jemsite's Avatar
Hello! I got it for $1400 USD is that still too high do you think? Thanks!
$1400 much better.
jemsite is offline
post #8 of 16 (permalink) Old 07-31-2017, 07:14 PM Thread Starter
Thanks so much guys! I tried using my 2mm key and it doesnt feel like its connecting with/fitting in anything in the stud. When I raise the post with the 3mm theres an initial cracking/popping sound, like its coming out of or off the lock and then it moves freely like a regular non lucking stud. With it loosen off I tried using the 2mm key and still it didn't feel like it was going into/connecting with anything down there. When I lower the bridge to the same position it makes the same noise like its re engaging but then theres a lot of resistance to lower it any further. I don't want to break anything so I just stopped there. Is there some special trick?
Thanks!
Opendome is offline
post #9 of 16 (permalink) Old 07-31-2017, 07:46 PM
Finding the hole is a bit of trouble for many virgins. The stud sets may or may not be installed. Measure how far in the wrench goes, it it's 25mm or more you have no set screws installed.
Rich is offline
post #10 of 16 (permalink) Old 07-31-2017, 08:01 PM Thread Starter
Hmmm the wrench goes it farther than that, the owner said the set screws are still in there. I can also feel the bridge hit something when it sort of makes a crack sound. I was also wondering does the set screw thread into the stud/bridge? Should I force the bridge down into the set screw?
Opendome is offline
post #11 of 16 (permalink) Old 07-31-2017, 08:35 PM
Apologies, the stud is 31mm, the set screw is 10mm. It could go 25+ and still have sets, not much more though. The only way to be positive is the get the allen seated in the set and turn it until it will not turn, then you know the allen is in the set.
Rich is offline
post #12 of 16 (permalink) Old 07-31-2017, 08:58 PM Thread Starter
No worries! Is the best way to back off the stud and then fish around in it for the set screw with a 2mm wrench?
Thanks!
Opendome is offline
post #13 of 16 (permalink) Old 07-31-2017, 10:41 PM
The best way is to do it locked, then you only turn it one way to know you're engaged. If it won't screw down, you're engaged.
Rich is offline
post #14 of 16 (permalink) Old 08-15-2017, 12:36 AM Thread Starter
Thanks so much for the replies guys! Its helped a lot! I always get paranoid about buying a used guitar and what has/hasn't been done with it. I noticed that if I put the 2mm in and just keep turning it does go up/down but I dont really feel it engage or anything. How exactly does the locking stud work? Do I screw it down, adjust the action and then raise it up again until it stops to lock it?
Thanks!
Opendome is offline
post #15 of 16 (permalink) Old 08-25-2017, 01:35 AM Thread Starter
Im having a hell of a time trying to figure this out. Do the studs lock when the screw is tightened or loosened? Do I back off the main posts before adjusting the lock? When I try to adjust it I feel some pressure and a sort of click?
Opendome is offline
j custom rg8570z neck
J Custom Neck question Fastmerc All Other Guitars (including Prestige) 0 02-13-2015 10:19 AM
Ibanez RG8570z J custom MiniMajs Classified Ads: Guitars and Gear 0 06-29-2014 10:44 AM
NGD: Ibanez J-Custom RG8570z-RS minv All Other Guitars (including Prestige) 19 02-01-2012 04:53 AM
NGD J Custom RG8570Z-BX DrJustice All Other Guitars (including Prestige) 20 02-26-2010 06:54 PM
New J-Custom for 2009: RG8570Z Dan_H All Other Guitars (including Prestige) 17 06-07-2009 11:16 PM
