J-Custom sound question - Jemsite
post #1 of 10 (permalink) Old 05-30-2007, 05:05 PM Thread Starter
The mahogany/flame combo is turning me off! I think that would sound too warm, so I'd like to ask for thoughts on this?
Alexeh is offline
post #2 of 10 (permalink) Old 05-30-2007, 05:29 PM
Re: J-Custom sound question
Probably has as much or more to do with your pickup selection. I have a Mahogany/Quilt Maple JC7 and it has great snap with PAF7s. I could imagine with an Evo 7 or X2N7 it would take your head off with high end.
eelblack2 is offline
post #3 of 10 (permalink) Old 05-30-2007, 08:11 PM
zEr0's Avatar
I'm with you, mahogany is not my body wood either. Even with a maple top it just sounds too muffled... And I hate bright pickups so that's not an option. BASSWOOD ALL THE WAY!!!
zEr0 is offline
post #4 of 10 (permalink) Old 05-30-2007, 11:03 PM Thread Starter
I have an alder, basswood and mahogany guitar but the basswood does seem just right! Basswood ftw!
Alexeh is offline
post #5 of 10 (permalink) Old 05-30-2007, 11:18 PM
To some extent. I have a RG3120 with mahogany/flame maple top and an RG8670 with mahogany/flame top, both with a ToneZone in the bridge, yet they sound remarkably different. These guitars are seemingly very similar, but so different in sound that I've come to the conclusion that if you want to know what a guitar is going to sound like, you've just got to play it. There is no substitute. You can speculate based on the specs, but each guitar has it's own quirky sound, however meticulously their makers try to make different instances of a given model identical. I own two instances of an RG520QS which sound different from each other, for instance.
Ferrous Lepidoptera is offline
post #6 of 10 (permalink) Old 05-31-2007, 02:49 AM
GAZ
The variations in pup height, action and freshness of the strings makes a difference between the sound of 'identical' guitars. Your 8670 has maple neck binding and an ebony board which will sound brighter than the rosewood on the 3120.
GAZ is offline
post #7 of 10 (permalink) Old 05-31-2007, 03:03 AM
GAZ
J Customs muffled ??? They have (usually) bolt on maple necks and a Floyd Rose type trem which increase top end and lose bottom end respectively. Both of mine with TZ pups can strip paint from the back wall if required, I rarely have the treble much above 4.5 on my Recto and the presence is on 1 ! Your amp set up is more important than your guitar in your overall sound. Invest in a quality valve/tube amp before you spend truck loads on guitars !
GAZ is offline
post #8 of 10 (permalink) Old 05-31-2007, 09:42 AM Thread Starter
Well not muffled really, but on the bassy side obviously since it's a piece of mahogany.
Alexeh is offline
post #9 of 10 (permalink) Old 05-31-2007, 12:41 PM
As Gaz said, setup can make a huge impact on the overall sound of otherwise identical guitars. I have no problem whatsoever making a HRG4-BX bark on the high end. Most of my guitars have different setups to accomodate various aspects of what I want it to play and sound like. For me, a wide assortment of pickups further broaden that range of tones.
post #10 of 10 (permalink) Old 05-31-2007, 11:42 PM
mi2tom's Avatar
+1!
mi2tom is offline
ebony board , flame maple , floyd rose , maple neck , maple necks , neck binding , pickup selection , tube amp
Transcript of Aussie Vai I'view (didnt know where to put it) TheOrangeChannel Ibanez JEM, UV, JS & Other Signature Models 16 07-25-2006 11:52 PM
blaze custom vs custom 7 (also called NEW 7) ibanez7addict All Other Guitars (including Prestige) 13 11-14-2004 10:04 PM
Question about Vai sound. Nilsefix Gear, Equipment, Recording & Off Topic 32 07-14-2004 10:21 AM
A simple question concerning the sound of RG3120 particlestorm All Other Guitars (including Prestige) 6 04-11-2002 03:48 AM
Evo7 vs. Blaze Custom? - My last question, I swear! bduersch Tech: Setup, Repairs and Mods 5 12-30-2000 02:04 AM
