Jackson Fusion vs RG feel: String spacing or radius? - Jemsite
post #1 of 3 (permalink) Old 03-24-2015, 11:41 AM Thread Starter
Hey, I've got a question for anyone who's played on both Wizard necks and classic Jackson necks: Is the string spacing on the Edge Pro the same as Jackson's JT580LP, or is it a tiny bit wider? Or does it just FEEL wider because of the flatter fretboard radius?
Last night, I was comparing my RG1550M to my old 90s MIJ Fusion, and I swear the strings feel closer together on the Jackson whenever I'm string-skipping, but I really couldn't see much of a difference when I whipped out the little ruler on the Ibanez multi-tool. But I can't guarantee I was holding my head and the ruler at the exact same position every time...
By the way, in reading around, I find that the spacing on the original edge is 0.420 or about 2-1/8" E-to-E. Can't find confirmation of the Edge Pro or the JT580LP for that matter.
highgainix is offline
post #2 of 3 (permalink) Old 03-24-2015, 09:33 PM Thread Starter
Re: Jackson Fusion vs RG feel: String spacing or radius?
Well, I've been unsuccessful in finding this info online, so maybe no one but the people with the design files at Jackson and Ibanez knows.
But, these are the best measurements I could do by hand with a ruler, again comparing a Jackson Fusion with a JT580LP bridge and an RG1550M with an Edge Pro. All values approximate, and I tried to round to nearest the nearest 0.25mm, based on where the center of the string appeared to be between the notches.
At the trem posts (E to E)
JT580LP: 52mm
Edge Pro: 53.5mm
24th fret
JT580LP: 48.5
Edge Pro: 49.5
The 1.5mm difference across the strings at the bridge means that I'm not just imagining the difference in feel with picking. That implies 0.3mm wider spacing between strings on the Ibby, which is pretty damn small, but perhaps not so subtle to miss.
Doesn't anyone else feel like the spacing is just a little wider on a prestige neck+edge pro guitar versus other floating trem setups?
post #3 of 3 (permalink) Old 03-24-2015, 11:07 PM
I feel that too on my ESP.
But when I do actual measurement with a steel ruler, the distance between strings are the same 1 cm on both Ibanez and ESP. ( @12th fret)
So I'd guess it's more because of the rounder radius on the ESP makes the string spacing felt a little narrower.
psychoshredder is offline
ibanez , jackson , radius , string spacing
NGD 1993 JACKSON FUSION STD bomberdude All Other Guitars (including Prestige) 10 04-29-2012 02:14 PM
WTB Jackson Fusion cmd130 Classified Ads: Guitars and Gear 3 07-22-2010 07:39 AM
Gotoh Floyd string spacing vs Edge Pro 2 string spacing Andy Mclaughlan Tech: Setup, Repairs and Mods 2 05-07-2009 10:37 PM
Pole Spacing - Difference between F-spacing and ordinary spacing on dimarzion evo's corkyo4 Pickups & wiring 1 04-09-2007 07:36 AM
anyone play a 16" radius neck? How does it feel vs. 12& SilverSurfer2 Gear, Equipment, Recording & Off Topic 13 05-07-2004 03:38 PM
