JS guitars.. 22 frets or ? Would S neck work on JS body? - Jemsite
post #1 of 5 (permalink) Old 12-23-2012, 08:53 AM Thread Starter
Reviews: 7
Hey guys. Would an S series 22 fret neck work on a JS body? I'm assuming the JS is a 22 fret guitar. I can't remember, but I'm thinking with my Video's of Satch that those were 22 fret guitars.? Anyway, my S series is cool, but I love that JS body. I'd just like to use it with the S series neck I have which is 22 frets. Also, the S series has a low pro edge and wondering if it would just drop in if the neck would work with the JS body? I dig that body, but don't want to buy a new guitar.. It would be cool to buy just the body and customize it..
Thanks
Tim
HoosierDaddy is offline
post #2 of 5 (permalink) Old 12-24-2012, 12:59 AM
Re: JS guitars.. 22 frets or ? Would S neck work on JS body?
Neck radius is different. Not sure what the heel width is for each but the neck pocket shape either. The Lo Pro Edge is a 430mm radius. I know the Edge Pro that was used in the JS used shims to achieve the correct radius and you'd just take those out if you're using the S neck.
The LP Edge, depending on the original tremolo that came with the JS could just drop right in.
MichelIV is offline
post #3 of 5 (permalink) Old 12-24-2012, 01:46 AM
RGTFanatic's Avatar
It can definitely be done, but everything depends on the year and series of both your neck and the body you buy. The S-series mostly came with 22-fret wizards (1 or 2). The neck pocket on JS bodies will be 56, 57, or 58mm wide depending on the year. measure your heel to determine which body you need.
edit: BTW....radius wont matter. If I'm understanding correctly, your using the Lo-Pro from the same guitar as the neck. The radius of each should be the same.
RGTFanatic is offline
post #4 of 5 (permalink) Old 12-26-2012, 11:44 AM Thread Starter
Reviews: 7
Hey guys.. Thanks so much. RGTFanatic. I'm using the Low Pro Edge from the S series. I don't know what's used with the JS, but I just like that body shape, etc,. I thought it would be cool to use the 22 fret neck from the S on a new JS body, but I understand there are some issues. I'll probably be better off waiting to find a good used JS.
I love that body style that the JS uses.. Doesn't it use an older body style called the saber or something?
Tim
post #5 of 5 (permalink) Old 12-26-2012, 11:54 AM
I believe the 540R (Radius) is the "original" JS. There are a number of people who make new 540R bodies too and you can find them on the bay. Might be a better alternative if you're just looking for a thicker super strat style body to go with your S neck.
MichelIV is offline
js series
Will an AANJ Viper Neck work with 540R Body? Monsta-Tone All Other Guitars (including Prestige) 0 03-01-2012 10:57 AM
FS: Carvin Bolt neck on Quilted Strat body - SS Frets, etc NickCormier Classified Ads: Guitars and Gear 1 10-03-2010 10:39 PM
Custom Project: JS, neck-thru, 24 frets, TUBAR√O GUITARS SWIRL: LOTZ of pics inside!! WillTubarao Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 125 06-02-2010 07:50 PM
Ibanez PGM 30 body, Lo TRS trem, will a Lo Pro work on this body? born2liftanitowoc Tech: Setup, Repairs and Mods 1 07-21-2007 10:25 AM
will a Rg neck fit and work on a saber body? serranasweep All Other Guitars (including Prestige) 7 12-16-2005 01:15 PM
