JCRG Differences between 1702 and 1802 - Jemsite
post #1 of 5 (permalink) Old 09-25-2005, 11:23 AM Thread Starter
Just as the title says. What are the differences between these two guitars if any? They look very similar. Thanks!
Regards,
Daniel
MidusGT is offline
post #2 of 5 (permalink) Old 09-25-2005, 01:35 PM
Re: JCRG Differences between 1702 and 1802
Both guitars were both available in SLK (which is the most likely finish to find the 1702 in, even though there was another finish color offered). The difference between the two guitars is that the 1702 has no neck binding and a natural bound body, the 1802 has neck and headstock binding and full ivoroid body binding with some sort of striped purfling material (like what you would see on an acoustic).
Soloist is offline
post #3 of 5 (permalink) Old 09-25-2005, 06:17 PM Thread Starter
Would the 1702 be comparable to the RG3120 Prestige?
MidusGT is offline
post #4 of 5 (permalink) Old 09-25-2005, 07:08 PM
Yes, in all but one important difference, the neck on the RG1702 is an Ultra (like the 2020/2120X, RGT, or RG-PR series). Another less significant attribute is that the 1702 has the strap locks inset into the body, it is a very cool and unique feature but unlike the 3120, which can use strap locks or a regular strap, the older inset strap locks will only allow a strap to be connected if it is using the locks that go with the same type of locks installed in the body. (hope that makes sense)
Soloist is offline
post #5 of 5 (permalink) Old 09-27-2005, 12:29 PM Thread Starter
Thanks so much for the replies, Soloist! Tons of insight and it seems like this guitar may be right up my alley. To my recollection, I enjoyed a RGT3020's neck more compared to the Rg Prestige wizard. I might have to pick one up. Thanks again, man!
Daniel
MidusGT is offline
headstock binding , neck binding , prestige wizard , strap lock , strap locks
jcrg-2 jooloo Classified Ads: Guitars and Gear 0 11-30-2011 10:01 PM
Ibanez Model 1802 WakingTheDemon All Other Guitars (including Prestige) 0 07-28-2011 09:40 PM
FS: JCRG 1702 xerxes994 Classified Ads: Guitars and Gear 12 03-22-2010 10:53 AM
JCRG - New or not?? Marcus All Other Guitars (including Prestige) 4 08-27-2001 04:46 AM
