Just got my J-Custom RRG6. Need Edge Zero HELP!! - Jemsite
post #1 of 3 (permalink) Old 03-05-2009, 04:40 PM Thread Starter
Hi guys,
Just received one of these limited edition J-Custom RRG6 guitars from meestursparkle:
J Custom RRG6
It is a great guitar, but I cannot get the Edge Zero bridge to stay in tune for anything. When I depress the bar it returns out of tune on several strings. I can sometimes get around this by pulling up hard on the bar after depressing it, however, that is an impractical solution. I read the manual, but I did not find information that helped me solve the problem. I tried messing with the roller adjustment, but that didn't do it. The trem is sitting perfectly parallel to the top of the body.
Bottom line - this is the only Floyd style double locking tremolo I've ever used that seems worse than a standard trem... I know it is just a simple setup problem, but I haven't solved it...
Anyone have any setup tricks or suggestions, etc. for keeping this thing in tune when using the bar? All the rest of my Floyds, I can abuse like hell and the guitar stays perfectly in tune...
Thanks,
Steve
sah5150 is offline
post #2 of 3 (permalink) Old 03-06-2009, 01:29 AM
Re: Just got my J-Custom RRG6. Need Edge Zero HELP!!
check the nut screws, not a shifting nut? neck screws? what is the angle of the trem? you can't use the edge zero with the knife edges parallel to the guitar with the ZPS bar in and working properly.
have you put in the locking studs it came with?
anyway, i can't be bothered writing out an exhaustive list, so check this, 99% guaranteed to solve your problem.
http://www.ibanezrules.com/tech/setu..._stability.htm
oh and so you know, i have an edge zero, and it always returns to perfect tune.
Homebake is offline
post #3 of 3 (permalink) Old 03-06-2009, 09:24 AM Thread Starter
Thanks for the response...
Oh btw - I'm an idiot! The Floyd nut screws weren't tightened! The whole system stays in tune perfectly now... Thanks for all the suggestions... I actually like the edge zero. The way the bar attaches is very clever...
Steve
sah5150 is offline
edge zero issue
New J-custom RRG6 spacebard All Other Guitars (including Prestige) 26 01-15-2009 02:09 PM
IBANEZ EDGE CUSTOM ALUMINUM TREMOLO BLOCK pictures thunder7 Classified Ads: Guitars and Gear 2 08-29-2008 12:36 AM
Custom Ibanez RG570/470 Edge trem w/refinish-You customize it! frankfalbo Classified Ads: Guitars and Gear 0 12-04-2005 11:43 PM
Problem with my J-custom EDGE Pro Trem =( artificial infection Tech: Setup, Repairs and Mods 6 09-11-2004 08:06 PM
