Lefty Trem Questions - Jemsite
post #1 of 3 (permalink) Old 01-29-2006, 06:45 PM Thread Starter
I have a lefty S470 that I love, but it has the LO-TRS-II trem. I was wondering if I could replace it with a Floyd Rose Pro without any routing. Also, on the Floyd Rose site, they said that the string spacing was narrower on the Pro than the OFR. Is the spacing narrower than the spacing on the lo-trs II?
Thanks
mikethedigimon is offline
post #2 of 3 (permalink) Old 01-29-2006, 07:48 PM
Smile Re: Lefty Trem Questions
Hi Yes i think so...
I have an 555 and i hated the LO TRS II so i replaced it with a orginal floyd rose the only thing i had to do was to switch the block they fits on both..
You have to take the block from the lotrs to the OFR but it is no problem. You have to do that because the block on the OFR is to long for the ibanez jem body.
I hope this help.. after i switched the trem to OFR i've got a better 555 and more stable in tuning..
All the best...
Glados is offline
post #3 of 3 (permalink) Old 01-30-2006, 03:41 AM
You should be able to do a direct swap with an OFR.
Regards
André
fettouhi is offline
floyd rose , floyd rose pro , ibanez jem
LoTrs7 - Trem (and/or) Arm replacement (Lefty plea for help) Astrocreep Tech: Setup, Repairs and Mods 4 02-09-2007 12:01 PM
Lefty Edge Trem Arm Go49rs110 Classified Ads: Guitars and Gear 2 01-03-2007 10:40 PM
FS: Ibanez lefty Trem arm for Edge - Lo Pro Ant1981 Classified Ads: Guitars and Gear 0 05-30-2006 08:07 AM
Wanted: LEFTY trem arm for Ibanez EDGE tremolo jzlucas Classified Ads: Guitars and Gear 4 12-31-2005 06:21 PM
U-Bar Trem- why not use it on everything? cut lefty costs... Drew Comments to Ibanez 23 10-22-2002 01:21 PM
