Little intonation problem (RG470) - Jemsite
post #1 of 5 (permalink) Old 01-11-2006, 09:26 AM Thread Starter
Okay, I've got a slight problem. I have an Ibanez RG470 (I think - I bought it used and there wasn't much info on it) and the intonation is out. Very out. G at the 24th fret is a (very flat) G# out. Other strings, such as the high E, and near perfect. But the low E, is about a quarter tone sharp, and so on. And basically, there just isn't enough movement left in the saddles to correct the problem. Not nearly enough, really.
So, my question is, what exactly can I do? It's got an Edge bridge, and I'm wondering if replacing that would help at all, or if the guitar is, essentially, worthless now. I'd like to, if at all possible, salvage it, simply because the neck on it is absolutely flawless, and other than the intonation problem, it's a great guitar. But it's also pointless to play it when the intonation is that bad... so... Any suggestions? Ideas? I don't mind spending the money to get a new bridge, but I'd rather not waste the ~$150ish if it's not even going to help.
So.. yeah... Any ideas would be appreciated.
Spekko is offline
post #2 of 5 (permalink) Old 01-11-2006, 03:42 PM
Reviews: 120
Re: Little intonation problem (RG470)
Are you saying the saddles can't move any further due to the design, or they are seizing up? If it's an RG470 with an EDGE it's probably pretty old now and maybe the saddles are seizing due to dirt build up or corrossion or something. Maybe worthwhile pulling the bridge apart and giving it all a good clean and trying again. I'd say if you are still having difficulties you should probably go see a tech and get them to look at it, give it a set up.
LonePhantom is offline
post #3 of 5 (permalink) Old 01-11-2006, 09:17 PM
you've got a real problem there. i remember helping a friend to intonate his guitar but without luck. his guitar was experimented by an inexperienced luthier by placing a buzz feiten mod on the neck. now his guitar is sharp all over the guitar. i think what you can do is move the locking nut a few millimeter towards the headstock. it's a difficult mod, better send it to a luthier.
silverarj is offline
post #4 of 5 (permalink) Old 01-11-2006, 10:14 PM
You don't need a new bridge, usually when you have trouble setting intonation, your neck has a bow and needs to be ajusted. You can fix it yourself, just take off the truss rod cover and tighten it up one eigth at a time and keep checking the strings and set the intonation. you'll notice your strings will go sharp some before you set intonation. I have fixed many many guitars like this with the problem you are having. Good luck bro. Let me know if you need more help.
guitarmanaic is offline
post #5 of 5 (permalink) Old 01-11-2006, 11:34 PM
It doesn't sound like he's aware of intonation at all. So, Spekko, read up on Rich's tech section on intonation, that should solve your problems.
Ibateur is offline
buzz feiten , edge bridge , locking nut , truss rod , truss rod cover
Jem 7v intonation problem jgparker Ibanez JEM, UV, JS & Other Signature Models 17 02-08-2015 03:18 PM
intonation problem on my 550 ftw1422 Tech: Setup, Repairs and Mods 17 12-17-2010 04:04 PM
intonation problem griever88 Tech: Setup, Repairs and Mods 6 10-27-2009 02:52 PM
A problem with '89 FP intonation. Ad_Astra Tech: Setup, Repairs and Mods 12 09-27-2007 02:15 AM
Problem wiring Rg470.... Rotti Tech: Setup, Repairs and Mods 7 10-04-2002 12:08 AM
