lo-pro 7 direct swop in RG7420 - Jemsite
post #1 of 2 (permalink) Old 08-10-2007, 12:25 PM Thread Starter
Will a lo-pro 7 directly swop into a RG7420 without routing?
Thanks for the info.!
evolvedmb is offline
post #2 of 2 (permalink) Old 08-10-2007, 01:07 PM
Re: lo-pro 7 direct swop in RG7420
This one comes up a lot. Best I've heard is "maybe" - some guys have evidently suceeded, whereas others have had to route, from what I've been told. Either way, you'll want to replace the trem studs, which is a professional job since it requires an anchor swap, too.
Your best bet is probably to swap the LoTRS for an OFR7, which is both cheaper than an Edge7, and arguably at least as high quality.
Drew is offline
trem studs
Pickup Surrounds or Direct Mount? atheesan0802 Pickups & wiring 16 01-28-2007 06:25 PM
What multi effect to use direct to mixer PA? DotNetTim Gear, Equipment, Recording & Off Topic 13 05-21-2005 12:48 AM
Looking for a good FX pedal to run direct... Drache713 Gear, Equipment, Recording & Off Topic 0 01-16-2005 12:18 PM
ibanez guitars with direct mount pickups shaddoe Tech: Setup, Repairs and Mods 7 10-13-2003 11:34 PM
Help with rg7420 information Monty-Jay All Other Guitars (including Prestige) 5 01-21-2003 05:52 PM
