Lo-pro Edge or Edge Pro? - Page 2 - Jemsite
post #16 of 20 (permalink) Old 04-04-2008, 09:19 AM Thread Starter
Re: Lo-pro Edge or Edge Pro?
Done! The problem is my mistake on installing the bushes. The dotted side should be installed toward the arm's tip. Anyway how long the tape trick will last?
badguitarist is offline
post #17 of 20 (permalink) Old 04-04-2008, 09:25 AM
jb4674's Avatar
Reviews: 18
Depending on how much whammying you do, it should last for a couple of weeks. On normal usage, it should go for longer than a month. I've had the tape ony JS1000 for a couple of months and it's still holding up relatively firm, though there's just a tad of looseness when I sit down, as the arm swivels toward the volume button and it stops there.
Jimmy
jb4674 is offline
post #18 of 20 (permalink) Old 04-04-2008, 11:28 AM
Originally Posted by LordGrendel View Post
...and didn't buy the even worse album before the amazing "Scenes From a Memory", "Falling Into Infinity"... but I own everyone before that and that is the only solo I remember him remotely even using his tremolo...
1.) You kidding me? I LOVE that album. Different strokes for different folks, I guess, and maybe it's a generation thing, but...
2.) He does a lot of bar slurs on his "Home" lead break, at the very least.
Drew is offline
post #19 of 20 (permalink) Old 04-06-2008, 12:14 AM
What happens if you wrap the tape and THEN put the bushings on? Seems like the tape would last a while then.
albee1952 is offline
post #20 of 20 (permalink) Old 04-06-2008, 07:13 AM
That's the intended purpose, the bushing are put on over the tape.
DarthLamer is offline
addario strings , arm holder , ibanez jpm , pro edge , trem arm , tremolo arm
edge pro to lo pro rya Ibanez JEM, UV, JS & Other Signature Models 54 11-11-2012 03:24 PM
edge 3 to lo pro edge hoockey All Other Guitars (including Prestige) 16 11-22-2006 04:15 AM
Can I use Edge posts with an Edge Pro?? PatrickSimsCustomShopUSA Tech: Setup, Repairs and Mods 8 10-26-2006 10:00 AM
String spacing of Edge/Lo-Pro vs Edge Pro MetalZone All Other Guitars (including Prestige) 21 10-24-2006 07:59 AM
Edge III Mystery... Solved? eclecticmage Tech: Setup, Repairs and Mods 47 10-22-2006 12:08 PM
