Lo Pro Help - Jemsite
post #1 of 6 (permalink) Old 09-21-2010, 11:46 AM Thread Starter
blf
Lo Pro Help
Hi all -- the Lo Pro on my 91 rg 550 is not coming back to "the zero point". If I dive and come back up Im flat and if I pull up on the trem it comes back down but stays sharp.
Springs? Spring Placement? Im using elixer 9-42 and the trem springs are in the "triangle shape" Not enough tension?
I have OFR lying around, is that a big route hassle to install that on the RG?
blf is offline
post #2 of 6 (permalink) Old 09-21-2010, 01:42 PM
Thumbs up Re: Lo Pro Help
it has to do with knife edge of the trem.
have you tried lip baum on the knife edge?
check this: http://www.ibanezrules.com/tech/setup/fat_knives.htm
its explain your problem.
thanks again Rich!!
modulo is offline
post #3 of 6 (permalink) Old 09-21-2010, 02:02 PM Thread Starter
blf
Re: Lo Pro Help
It seems that applies to later models? mine is a 1991. Instructions for pulling the trem and sharpening the knife edges ?
blf is offline
post #4 of 6 (permalink) Old 09-21-2010, 02:59 PM
Re: Lo Pro Help
you have to change them for new one's
to remove the trem: remove the springs without touching the claw.
it will come out. remove the stud, buy new one from rich.
http://www.ibanezrules.com/parts.htm#Trem Parts
and for the knife edges, ask Rich!!
Pascal
modulo is offline
post #5 of 6 (permalink) Old 09-22-2010, 04:38 AM
Reviews: 120
Re: Lo Pro Help
Why do the knife edges need to be replaced? It probably needs some chap stick, or at most a bit of a file.
LonePhantom is offline
post #6 of 6 (permalink) Old 09-22-2010, 10:02 AM
Re: Lo Pro Help
try NEW springs first bro
jym-ellis is offline
lo pro trem
