LO-TRS 2 trem replacement? - Jemsite
post #1 of 6 (permalink) Old 06-12-2017, 01:24 PM Thread Starter
I just bought an S470 for $130. It has the LO-TRS 2 trem on it but didn't come with the arm. I thought I was getting a smokin deal and I could just get a replacement arm for a few bucks. I can't find one anywhere! So now I am considering replacing the trem altogether but from what I've read only the original Floyd Rose is a direct fit and that will cost more than the guitar? Here are my questions:
1.) Are there any other arms from another trem that will fit the LO-TRS 2?
2.) Are there any cheaper alternatives other than the original Floyd rose as a drop in replacement?
Thanks!
kuhndoggy09 is offline
post #2 of 6 (permalink) Old 06-12-2017, 01:26 PM
Re: LO-TRS 2 trem replacement?
The bar is $18 plus mail
[email protected]
Rich is offline
post #3 of 6 (permalink) Old 06-12-2017, 09:26 PM
Reviews: 120
From memory, don't any regular Floyd Rose spec collared screw on arm fit?
You'd want to replace the LO-TRS II if you enjoy the guitar and wish to keep it long term. If it's not already worn out it will be soon. The Gotoh Floyd Rose is cheaper than a original Floyd, and considered by many to be superior. If it doesn't fit, it will with a little bit of sanding to the cavity. Make sure you replace the studs and anchors while you'er at it. Pull the old ones out, drill for the new anchors and install.
LonePhantom is offline
post #4 of 6 (permalink) Old 06-12-2017, 11:39 PM
Possibly, I only know factory as that's all I handle.
Rich is offline
post #5 of 6 (permalink) Old 06-13-2017, 10:37 AM
The gotoh 1996 floyd usually fits the lo-trs 2 route.
moebius is offline
post #6 of 6 (permalink) Old 06-15-2017, 08:13 PM
Reviews: 120
If you decide to keep the LO-TRS II for now, I've still got a bar lying around. Where are you located? I'm happy to send it to you for the cost of post if the cost works out not to be over the top for you
floyd rose , lo-trs 2 , s470 , tremolo
lo trs replacement... jbouxa Tech: Setup, Repairs and Mods 18 09-15-2010 12:10 AM
Ibanez LO TRS II replacement trem Steve Vai's Kid Tech: Setup, Repairs and Mods 9 07-13-2010 09:28 AM
Best Replacement for Low TRS II Trem? ggl Ibanez JEM, UV, JS & Other Signature Models 15 03-20-2010 11:56 AM
Replacement for Lo TRS Trem 2 on S470 Leader Tech: Setup, Repairs and Mods 3 01-26-2006 10:19 PM
lo trs II replacement superpato Tech: Setup, Repairs and Mods 2 10-24-2003 02:47 AM
