Lo-TRS II replacement for s470??? - Jemsite
post #1 of 4 (permalink) Old 01-22-2009, 01:39 PM Thread Starter
I recently obtained an older s470 qs that came with a lo-trs II trem. I've heard numerous people explaining how horrendous the lo-trs II was so I'm considering an upgrade. I really like the edge bridges but I've heard that aside from routing (which I wouldn't mind doing) that the post spacing is different. lo-trs has 74 mm while edge pro's have 73mm?
does a half millimeter on each side make that much of a difference? since one of the knife edges is totally straight and not rounded might it still fit barely?
maverick52 is offline
post #2 of 4 (permalink) Old 01-22-2009, 01:52 PM
Re: Lo-TRS II replacement for s470???
No offense intended, but if you do a search you may find a lot of threads on replacing lo-trs II trems. This has been discussed many times before.
Good luck.
moebius is offline
post #3 of 4 (permalink) Old 01-22-2009, 05:20 PM
Reviews: 120
Gotoh licensed Floyd Rose - go get it! Locking studs too so take the time to replace the LO-TRS II studs and anchors.
LonePhantom is offline
post #4 of 4 (permalink) Old 01-25-2009, 06:22 PM
I got a schaller floyd rose from Stewmac. solid brass block really really really improves the sound of the guitar and it holds tuning like nothing else i know! plus it just drops into the cavity of the Low TRS II, so no mods needed which is good if your a menace with electric tools.
schmintan is offline
edge , lo trs , lo trs ii , s470 , tremolo
Got the S470! UsrName All Other Guitars (including Prestige) 15 05-11-2007 06:14 PM
Old S470... Matt08642 All Other Guitars (including Prestige) 5 10-24-2006 11:31 AM
Replacement for Lo TRS Trem 2 on S470 Leader Tech: Setup, Repairs and Mods 3 01-26-2006 11:19 PM
replacement neck for s470? superpato All Other Guitars (including Prestige) 3 08-03-2004 12:02 AM
Suggestions for replacement PUP's for S470 JLM777 Pickups & wiring 12 03-04-2003 12:17 AM
