low B guages - Jemsite
post #1 of 49 (permalink) Old 06-06-2005, 03:01 PM Thread Starter
low B guages
what gauge do people use for their low Bs, mine came with a standard 9-52 set on, but i beffed it up a bit to a 54, but still not entirely happy, what bottom would people recommend i try (to save the hassle of trial end error haha)
Last edited by timi_h; 06-06-2005 at 03:04 PM. Reason: spelling error, rather important aswell!!
timi_h is offline
post #2 of 49 (permalink) Old 06-06-2005, 03:33 PM
Re: low B guages
I've been using 60's and 62's for a couple years now, never had problems with tuning and intonation etc. Thats just me tho
ibanezrocker61 is offline
post #3 of 49 (permalink) Old 06-06-2005, 03:35 PM
Flobanez's Avatar
Re: low B guages
I use 9-52's on all my 7-strings.
Flobanez is offline
post #4 of 49 (permalink) Old 06-06-2005, 03:59 PM Thread Starter
Re: low B guages
what do you use for the rest of the guitar, and if you went up to a kinda 10-46 with 60 on the bottom did you find that you needed to do anything to the trem interms of adding springs/changing to arrow config?
timi_h is offline
post #5 of 49 (permalink) Old 06-06-2005, 06:47 PM
Re: low B guages
How do you get enough tension in a .52 low B ?
I'd prefer to use a .52 low B myself but I find it really difficult to get enough tension out of anything thinner than a 58.
Any ideas ?
JTM45 is offline
post #6 of 49 (permalink) Old 06-06-2005, 07:17 PM
Re: low B guages
I use 9-42's with either a 54 or 56 for the B.
stretcher7 is offline
post #7 of 49 (permalink) Old 06-06-2005, 07:19 PM
Re: low B guages
Yup they are 10's, on my 7620, the edges only allow for 3 springs so it has 3, the claw is basically almost all the way tightened, i put the trem tilted back just a little.. no problems at all. on my 7420, I have 5 springs, claw is 3/4 in, bridge tilted back a little, also no problems. On my Jackson 7's (two DR7's), they are the ones with t.o.m./string-thru bridges.
post #8 of 49 (permalink) Old 06-06-2005, 07:21 PM
Flobanez's Avatar
Re: low B guages
JTM,
The tension is just right for me actually.
I bought my PWH from Rich and he set it up mint. How he does it? I'd like to know.
My RG 7620 has had numerous various gauged strings so the trem has been messed with alot and finally its back to normal. I had a tech from a music store set it up and it's nowhere near as good as Rich's set-up.
My S 7420 has had 9's ever since I bought it. It was straight from the factory and the set-up again is nowhere near as good as Rich's set-up.
Flobanez is offline
post #9 of 49 (permalink) Old 06-07-2005, 07:42 AM
Re: low B guages
I use .011 to .050 with a .070 on the low B, which i tune down to A.
darren wilson is offline
post #10 of 49 (permalink) Old 06-07-2005, 11:40 AM
Re: low B guages
I use 9-42 with a .56 or .58 B. .58 is ideal in terms of balance between it and the E, but Elixer doesn't make one yet.
I agree, .52 is WAAAY too light.
-D
Drew is offline
post #11 of 49 (permalink) Old 06-07-2005, 11:48 AM
Flobanez's Avatar
Re: low B guages
It's not too bad for me. I do prefer a .56 every now and then on my 7620 but since I've stocked up on .52s,
I haven't bought any .56s for a while.
I generally dont play rough as I used to when I was playing just metal so the tension is just right for me.
Flobanez is offline
post #12 of 49 (permalink) Old 06-07-2005, 12:45 PM
Re: low B guages
D'Darrio 9-46 (its a hybrid set, EXL125),and a 56 for the B.
Think about it
D - 26
A - 36
E - 46
B - ? Take a guess.
The perfect match for a well balanced guitar.
If i have the B dropped to A, then i replace with a 59, only cause D'Darrio doesn't make 58's.
1wi11 is offline
post #13 of 49 (permalink) Old 06-07-2005, 12:49 PM
Re: low B guages
I use a standard D'Addario XL110-7 set: .010-.056. No problems so far.
jeffrey is offline
post #14 of 49 (permalink) Old 06-07-2005, 05:37 PM
Re: low B guages
...while I, on the other hand, have a fairly heavy pick attack.
Really, I should probably look into moving to tens...
-D
Drew is offline
post #15 of 49 (permalink) Old 06-07-2005, 05:52 PM
Re: low B guages
Me too^
phlame is offline
addario strings , ernie ball , local music shop , music store , string tension , trem block , zakk wylde
Your string guages are wrong! Dino Gear, Equipment, Recording & Off Topic 238 05-05-2008 06:34 PM
Tuning Down and String Guages slugman Tech: Setup, Repairs and Mods 7 09-06-2005 05:08 PM
K-7 guages... Akhenaten All Other Guitars (including Prestige) 6 12-01-2002 04:50 PM
Down Tune - String Guages Two hands31 All Other Guitars (including Prestige) 15 02-27-2002 05:18 PM
String Guages - I'm well stuck in my rut! Devo Ibanez JEM, UV, JS & Other Signature Models 20 06-21-2001 01:17 AM
