Low B Saddle On Lo Pro Edge-7, Intonation - Jemsite
post #1 of 5 (permalink) Old 11-05-2003, 12:09 AM Thread Starter
I've got this RG 7620 and I can't get the Low B saddle far enough back for proper intonation. I have not experienced this on my Universe. I use a .054 for the low B, but I switched to a .052 on the 7620 because thinner strings don't seem to need to be as far back. But it didn't solve it. Anyone else experience this? I somewhat fixed it by tuning the fretted D on the low B, 3rd fret, rather than tuning the low B (when I tune the guitar I mean) because fretted notes were going too sharp if I tuned the low B.
CrossingStar is offline
post #2 of 5 (permalink) Old 02-24-2004, 04:44 AM
I have almost experienced this
Hi man, yeah the low B needs to be heaps far back
Mine is so far back, when I change strings, I find it hard to unscrew the allan bolt holding in the string, and vice versa (becaue the fine tuner gets in the way of my allan key)
Although, my saddle is far enough back to make the intonation right.
I didn't have a problem with 56 - 60's
Did you know there are 2 holes in which you can use for the allan bolt locking the saddle in place. I used to 2nd hole in oder to get the extra length in my B string.
Joshka is offline
post #3 of 5 (permalink) Old 02-24-2004, 11:35 PM Thread Starter
I've since sold that guitar. Couldn't deal with that & other problems with it.
post #4 of 5 (permalink) Old 03-01-2004, 07:14 AM
what were the other problems?
Joshka is offline
post #5 of 5 (permalink) Old 03-01-2004, 07:16 AM
Did you know there are 2 holes in which you can use for the allan bolt locking the saddle in place?
Joshka is offline
saddle all the way forward, intonation still off flat windycitycane All Other Guitars (including Prestige) 12 01-25-2014 07:12 PM
saddle screwhole stripped in edge zero . intonation problems?? bonsuer Tech: Setup, Repairs and Mods 1 05-11-2012 09:34 AM
saddle screwhole stripped in edge zero . intonation problems?? bonsuer Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 05-10-2012 06:06 PM
damaged saddle/ intonation screw hole in edge zero 2 .. repair help?? :( bonsuer Tech: Setup, Repairs and Mods 8 05-05-2012 02:37 AM
intonation tweaks - nut? bridge saddle? neck? what? germX Tech: Setup, Repairs and Mods 3 05-09-2001 04:39 PM
