Low tuning setup - Jemsite
post #1 of 12 (permalink) Old 12-16-2009, 12:06 PM Thread Starter
Low tuning setup
Hey guys I've got an RG350 with all the standard stock stuff on it. I want to tune it lower to like C or may be C sharp. I know the basics of guitar setup but any caution, ideas or experience from you would be appreciated. Or maybe you dont think it's a good idea because of the 25" scale length of this particular guitar? I am definitely going to get higher gauge strings than the factory 9's.
latemm is offline
post #2 of 12 (permalink) Old 12-16-2009, 01:52 PM
Re: Low tuning setup
I've used a CGCGCE tuning with heavy gauge strings on my 470 with no problem at all. A baritone would be better, but at least for me the 25.5'' scale was not a issue. Good luck!
Aris_T is offline
post #3 of 12 (permalink) Old 12-16-2009, 03:47 PM Thread Starter
hi aris_T,
Did you find yourself having to adjust the neck after the low tuning change?
latemm is offline
post #4 of 12 (permalink) Old 12-16-2009, 03:56 PM
I set up with 13s for C# standard on a 25.5" without too much drama. I would like the take a little bit of bow out of the neck which has developed, but this is a tele neck rather than an ibby, so yours will probably hold out better.
skins345669 is offline
post #5 of 12 (permalink) Old 12-16-2009, 06:14 PM Thread Starter
Interesting point about the neck type, thanks skins
latemm is offline
post #6 of 12 (permalink) Old 12-16-2009, 07:23 PM
I have my rgt set up for D and dropped C with Daddario xl11's. I used to have it tuned to B with ghs boomer zack wyld 10-60's but the third string was way too loose at only 017 but the other highs weren't as bad but still loose. way too heavy on the bottom and light on the top though since they were designed for dropped tuning. 10-13-17-36-52-60. I had to put the tremlo spring basically all the way into the body with these string to keep it flush though, slight neck bend developed too but just adjust it out.
You should be ok with 11's or 12's.
MrMcSick is offline
post #7 of 12 (permalink) Old 12-16-2009, 08:43 PM
I have my RG in C standard, but it requires a pretty unique string gauge set. I only order singles :/. I'm running .11-.59
hellboar is offline
post #8 of 12 (permalink) Old 12-16-2009, 08:59 PM
Originally Posted by latemm View Post
hi aris_T,
Nope, everything worked great. You should check your neck though and make the adjustments, if there should be any. I used a Big-n-Heavy DR string set (10-13-17-30-44-52) for this tuning.
Aris_T is offline
post #9 of 12 (permalink) Old 12-17-2009, 03:30 AM
yeah, I do it on my 87 RG560...drop C with 12s..just have to adjust your bridge and springclaw..with no neck problems..don't know why other people are having problems..
560licious is offline
post #10 of 12 (permalink) Old 12-17-2009, 08:32 AM
Get some 12's and see how it goes. You may need to turn the truss rod on way or the other, or shim the neck depending on what happens. I have done it without any changes on a few ibanez guitars.
crossbones is offline
post #11 of 12 (permalink) Old 12-17-2009, 05:26 PM Thread Starter
I used 11's and they seem solid. Problem is, no matter how much i read up on truly sighting the neck, I cant tell A) whats really going on with the neck and B) when i should adjust it or if anything happened to it when I changed string gauge or tuning.
latemm is offline
post #12 of 12 (permalink) Old 12-17-2009, 05:34 PM
I also use 11s in a dropC tuning...But i a have a fixed bridge. (RG2EX) 13s were way to big...11s work good on (my) RG. I did adjust the trussrod some. But i always play around with my necks.
DACE>
DACE is offline
low tune
tuning new jem... Devon8822 Ibanez JEM, UV, JS & Other Signature Models 7 11-02-2007 06:16 PM
korean locking nuts - loosin tuning does the hardware finish matters on tuning?? jlander Tech: Setup, Repairs and Mods 4 08-01-2006 08:43 PM
Setup problems with my DBK...good price for a quality setup? Guitarlos2 Tech: Setup, Repairs and Mods 7 07-10-2003 02:39 PM
EMG-ZW setup... 'Zakk Wylde's' setup. WHos got em? DrPuls Pickups & wiring 5 11-25-2002 07:17 PM
Tuning to E - Can't get back to E tuning with my UV777 Zmuzic Ibanez JEM, UV, JS & Other Signature Models 6 07-25-2001 12:12 AM
