MIJ RG550 - arm broke off in Edge - Jemsite
post #1 of 4 (permalink) Old 12-21-2017, 04:41 PM Thread Starter
Hi, I am new here. Great site.
As the title suggests, I was careless last night and broke the arm off inside the socket of my Edge trem while trying to get enough slack in the strings to pull my pickguard out. Rather stupid as I was in a rush to get something done and took a shortcut.
Is there a way to take off the socket assembly and replace it and the arm? Am I stuck drilling it out? The knife edges seem in good shape but I think there is a sleeve or something missing from one of the posts ( on the arm side) because I can see threads on one post but not the other so if having to replace the entire trem is the only option I am ok with that - but hate to have to spend the $$ I see them going for.
Any advise on how to fix this would be hugely appreciated. I am starting to work on my own gear so forgive me if some of these questions are very basic.
Dave J is offline
post #2 of 4 (permalink) Old 12-21-2017, 05:11 PM
Re: MIJ RG550 - arm broke off in Edge
i think you may be able to get the piece of the bar out of the arm holder if you unscrew the screw on the bottom and push something up there, could be wrong though. If you cant you can buy a new arm holder so don't worry.
Leviathus is offline
post #3 of 4 (permalink) Old 12-22-2017, 03:16 PM
You can remove the retainer spring it should be a Phillips screw then you can use a small rod and insert it into the hole and push the bar out
ShinkanPo is offline
post #4 of 4 (permalink) Old 12-22-2017, 04:09 PM Thread Starter
Thanks for the fix! Just having to find a replacement bar is much easier than the alternate on some trems.
Dave J is offline
arm , broken , edge tremolo
MIJ RG550 - arm broke off in Edge Dave J All Other Guitars (including Prestige) 1 12-21-2017 04:42 PM
Saddle Unit (EDGE PRO) broke after 1 week - normal? NickB Ibanez JEM, UV, JS & Other Signature Models 7 04-15-2007 02:03 PM
edge pro tremolo arm and arm holder adjustment tonesponge All Other Guitars (including Prestige) 6 10-12-2006 04:43 PM
Edge, Lo Pro. or Edge Pro? *DELETE, POLL BROKE* m0p Polls 0 10-16-2005 11:46 PM
my stick done broke off - tremolo arm broken swirlmutha Tech: Setup, Repairs and Mods 4 03-15-2001 03:07 PM
