Mismatch serial numbers on RG550 - Jemsite
post #1 of 3 (permalink) Old 12-17-2018, 02:01 PM Thread Starter
Hi all
New member here - Alan in the UK.
I own an RG1570 Prestige which I bought new a number of years ago - love it. I've just also taken delivery of my second Ibanez - a 2018 Genesis RG550 from fleabay. Everything on the 550 looks spectacular in terms of the Fujigen precision, fit and finish and it's virtually mint. The components all look genuine when I compare them with close ups on the web - Gotohs, Edge etc. The only problem is that the serial number on the neckplate doesn't match the five digits after the 18 year on the rear of the headstock. I also own Gibsons and the RG1570 and I can tell quality when I see it. I just have a bit of a worry because of the non matching serial numbers. Is this something that can just happen or do I have cause to investigate further?
The seller also messaged me a receipt which looked good from when it was purchased new.
Thanks in anticipation
Alan
AlanH is online
post #2 of 3 (permalink) Old 12-17-2018, 02:18 PM
Re: Mismatch serial numbers on RG550
Neck plate number will never match a headstock number.
The plates are JS plates and consecutive, although they're been used on everything from STW's to PGM's in the past.
Rich is offline
post #3 of 3 (permalink) Old 01-12-2019, 06:57 AM Thread Starter
Here are my two RGs...
'08 1570 in Suede Red
'18 RG550 Genesis in White
File Type: jpg IMG_20190110_174133596_1547290615829.jpg (4.62 MB, 28 views)
AlanH is online
NGD mismatch kRoG570 All Other Guitars (including Prestige) 2 10-13-2014 08:57 PM
Premium serial numbers : what does a letter mean infront of serial number? Santuzzo All Other Guitars (including Prestige) 2 03-16-2013 05:55 AM
Jem 10th Numbers & Serial Numbers chart stratosqueeg Ibanez JEM, UV, JS & Other Signature Models 9 10-26-2011 07:55 AM
neck and body mismatch Elliseye All Other Guitars (including Prestige) 8 06-25-2006 11:36 PM
Mesa Bias Select Mismatch big al Gear, Equipment, Recording & Off Topic 6 12-27-2002 02:05 PM
