MODS, Need Advice - Jemsite
post #1 of 6 (permalink) Old 04-15-2013, 01:06 AM Thread Starter
MODS, Need Advice
So I have 2 S Series Guitars with HSH configurations. I am planning on putting noiseless strat pups in the mid positions. Heres why; I want the middle positions to be noiseless, but I want stacked buckers so I can wire the switches to coil tap both the middle and the neck/bridge when in position 2&4 so that it is only two coils that are RPRW like on a Fender Strat and get that quacky sound as opposed to the full bucker and middle pickup.
The advice I need is how is the best way to do this with the super thin S series body? I'd like to use a super strat switch to hopefully avoid modifying the bodies, but I'm afraid it will be to large. does anyone have a schematic or a good suggestion on how to do this?
guitar guy is offline
post #2 of 6 (permalink) Old 04-15-2013, 02:26 PM
Re: MODS, Need Advice
The VLX91 is like a super switch and will fit the S.
Edit: Some S-series come with the VLX91 from the factory, check your guitar before you order.
just4kinks is offline
post #3 of 6 (permalink) Old 04-15-2013, 05:34 PM Thread Starter
Sweet! Thanks a ton!
post #4 of 6 (permalink) Old 04-15-2013, 06:07 PM Thread Starter
Duder, Thanks so much for that little part number, thanks to you I found this site which has the schematic for that switch plus the exact wiring for that configuration i wanted!
http://www.shredguitars.com/showthread.php?t=31910
post #5 of 6 (permalink) Old 04-15-2013, 06:53 PM
Reviews: 9
Make sure the pickup isn't too deep. Some S bodies only accept shorter pickup. I was going to install a SD Clask Stack Plus in a 570 but it would not fit.
fly_with_v is offline
post #6 of 6 (permalink) Old 04-16-2013, 11:18 AM Thread Starter
I will check, thanks again!
advice , ibanez , mods , s series
RG2550... looking for advice on aesthetics mods!! koijak All Other Guitars (including Prestige) 5 11-23-2011 08:44 AM
PMC mods Benjamin James Ibanez JEM, UV, JS & Other Signature Models 78 06-29-2009 02:14 AM
jem 555 mods drizzt75 Ibanez JEM, UV, JS & Other Signature Models 54 10-23-2006 09:13 AM
Amp Mods razorsuppository Gear, Equipment, Recording & Off Topic 2 04-22-2006 10:22 AM
Jem Mods other than LGM and EKG? typedeaf Tech: Setup, Repairs and Mods 4 02-14-2006 12:22 PM
