My Edge Pro drives me insane! - Jemsite
post #1 of 19 (permalink) Old 05-08-2009, 01:53 PM Thread Starter
So I've got the trem on my ibanez in level, in tune, the nut is tight, the strings are locked in VERY tight, and they're locked in VERY tight in the bridge as well.
STILL! It will go out of tune when i divebomb or just dive about moderately. mostly on the gstring that goes pretty flat.
it goes back to normal when i yank the bar up.
I know it shoulnt be like this and I've played Edge III's that have not even had this problem, and this is supposed to be an Edge PRO..
would it be the knife edges and string posts? should i get some kind of lubricant for them?
the trem is almost certainly "never used", so it shouldnt be a wear and tear problem.
anyone?
Thrashman is offline
post #2 of 19 (permalink) Old 05-08-2009, 02:01 PM
Cool Re: My Edge Pro drives me insane!
Hey man!
I have had a problem on the locknut, the little block that locks against the string had a spot wore out where it contacts the string. Pop that off and maybe flip 180 degrees.
See if that helps???
VK_UV_97 is offline
post #3 of 19 (permalink) Old 05-08-2009, 02:16 PM Thread Starter
I have tried, and it doesn't work
post #4 of 19 (permalink) Old 05-08-2009, 02:28 PM
WMerkert's Avatar
Have a look at the tech section of Ibanez Rules.
WMerkert is offline
post #5 of 19 (permalink) Old 05-08-2009, 02:36 PM
Its only the G string and when you pull up it goes back in tune? The strings got to be moving at the locknut.
Maybe try cutting a piece of notebook paper to fit it under the G string only, at the lock nut, lock it down, see what it does... that'll shim the string up about .010". It's temporary but see what it does?
VK_UV_97 is offline
post #6 of 19 (permalink) Old 05-08-2009, 03:52 PM
1.Try using other brand of strings see if that helps.
2. Adjust the tension on the springs in the back of the guitar slightly so all the strings go
slightly sharp. Then re-tune using the bridge tuners.
3. Check to see that the bridge screws are not loose.
4. Check the knife edges to make sure they are not worn out.
5. oil or lubricate the knife edges
Robstar is offline
post #7 of 19 (permalink) Old 05-08-2009, 04:06 PM Thread Starter
Everything is tight. everything is new.
I'll get some oil and chapstick/lipbalm tomorrow and see if it helps.
sucks that i cant even use the trem because it throws it outta tune.
post #8 of 19 (permalink) Old 05-08-2009, 04:26 PM Thread Starter
Alright, its setting most strings out of tune. gsting is most noticeable still.
Even with light diving.
WTF!?!?
post #9 of 19 (permalink) Old 05-08-2009, 04:31 PM
Hey man!
Have you checked out the tips in the Tech setups and F.A.Q on the home page?
There is a section in the Maintenance and Modifications "Tremolo Porblems - Why Can't I Stay in-tune?". Give that a read...
Hopefully this will help you out!
VK_UV_97 is offline
post #10 of 19 (permalink) Old 05-08-2009, 04:44 PM Thread Starter
I have, and all that is left is to use some lipbalm/chapstick on the knife edges and trem posts, as well as using some kind of oil on the 6 string-things on the trem.
Not sure what oils that work though.
This shouldnt even be happening AFAIK, with such a good trem. an edge III would hold tune lightyears better than this ****.
post #11 of 19 (permalink) Old 05-08-2009, 05:00 PM
In your other post you said... "I have no floating trem experience, not maintenance and such at least"... but, since then, it sounds like you have tried everything and researched, is there a local shop you can take it to?
I feel for you man and it shouldn't be giving you this much trouble!
VK_UV_97 is offline
post #12 of 19 (permalink) Old 05-08-2009, 05:03 PM
Your problem is procedural
http://www.ibanezrules.com/tech/setup/lockdown.htm
Rich is offline
post #13 of 19 (permalink) Old 05-08-2009, 05:13 PM
Thumbs up Re: My Edge Pro drives me insane!
Originally Posted by Rich View Post
That's a great read!
VK_UV_97 is offline
post #14 of 19 (permalink) Old 05-13-2009, 09:21 PM
rich is the master
spins is offline
post #15 of 19 (permalink) Old 05-13-2009, 09:42 PM
if you use lube, i recommend big bends nut lube. chapstick tends to gunk up if you ask me, and that can't be good. also, be careful tightening the string locks at the nut and bridge, you can strip them if you tighten to hard and then you're really screwed.
Foulacy is offline
Hard Drives Ant1981 Off-topic / Miscellaneous 9 04-15-2007 12:57 PM
PGM10th w/RGA carved top and monkey grip??? On the SAME GUITAR? It's insane, insane!! WillTubarao Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 73 03-22-2007 12:53 PM
Hard Drives? Darren Wonnacott Gear, Equipment, Recording & Off Topic 6 02-23-2007 06:10 AM
incredible Guitar Tube Drives dimitar Gear, Equipment, Recording & Off Topic 5 02-23-2005 05:58 PM
FireWire Drives Jejouelesguitares Gear, Equipment, Recording & Off Topic 7 07-01-2002 11:55 PM
