My edge pro and tuning - Jemsite
post #1 of 20 (permalink) Old 09-29-2003, 05:50 AM Thread Starter
I've just bought my first Ibanez guitar (I already have 2 Ibanez basses though), it's a lovely Rg1570 in Black. I've never used a FR style trem before but have got used to tuning it now, the problem I have though is when I pull back on the trem, edge pro, anymore than a tone the thing goes well out of tune, like each string goes out by about a semi tone. Is this the norm or should I stick to just going down?
sanitarium is offline
post #2 of 20 (permalink) Old 09-29-2003, 06:58 AM
If the guitar is new, implying the strings are also new, then the strings probably need to stretch some. That's a few days of not staying in tune (i.e. play, tune, play, tune, etc). If after some time you're still going out of tune, then check that the locking nuts are tight.
After that, you should check the tech sections just to be sure you have everything setup properly.
Ibateur is offline
post #3 of 20 (permalink) Old 09-29-2003, 12:53 PM
It takes 15 minites to stretch strings, not days, but I'm betting you're returning sharp which has nothing to do with string stretch.
http://www.ibanezrules.com/tech.htm#Sets
Rich is offline
post #4 of 20 (permalink) Old 09-29-2003, 06:08 PM Thread Starter
Cheers guys, it seems to be better now, I gave it a good half hour intensive crazy slayer style work out and it seems to be better. The tech bit on your site was great thanks Rich. Also I was tuning ok in the beginning but the intonation is a bit out, I'm a bit scared to do anything about it at the moment coz i've just bought it and don't want to do anything stupid like break a part of the trem.
post #5 of 20 (permalink) Old 09-29-2003, 06:13 PM
Unfortunately there is no intonation tool yet [and may never be with Japan working on it!] so any adjustments will be a long and painfull process. Make sure to have a few cold ones to help ease the pain
Rich is offline
post #6 of 20 (permalink) Old 09-30-2003, 04:33 AM
i dont see all that pain intonating a guitar with no intonation tool, though it's surely a waste of time.
nuno is offline
post #7 of 20 (permalink) Old 09-30-2003, 05:09 AM
Could've sworn it took me days of retuning to finally get stable. Wasn't using the trem though.
Ibateur is offline
post #8 of 20 (permalink) Old 09-30-2003, 12:27 PM
If you're used to doing it and know about how far the saddles need to move then pulling the trem and doing them all at once isn't too bad, otherwise, it still takes a long time.
Then you're not stretching them in enough before you lock down.
Rich is offline
post #9 of 20 (permalink) Old 09-30-2003, 02:18 PM
Did you provide instructions for this in your tech section?
Greg
gkelm is offline
post #10 of 20 (permalink) Old 10-01-2003, 05:09 AM
...pulling the trem and doing them all at once...
you need to pull the trem to move the saddles?
and what you mean "doing them all at once"?
nuno is offline
post #11 of 20 (permalink) Old 10-01-2003, 10:41 AM
If you're doing it with a tuner, as most people have to, you can't pull the trem to set the intonation.
You'll have to tune, check intonation, move the saddle sharp or flat, retune, recheck, etc.
If you have what's known as a "jig" to position the saddles, or if you've been doing it for years like Rich has, you can pull the entire trem and set the saddles to about where they should be (by eye) and be pretty derned close, if not right on.
I've painstakingly set the intonation on both of my guitars and cut a makeshift jig from hard plastic based on the positions the saddles are in. Both guitars match, amazingly. :-) I often end up setting up friend's guitars and this little "toy" helps, yes, even for guitars with different types of bridges the positions are almost exactly the same.
If you don't have the patience to do this job (yes, it is frustrating sometimes) have a tech do it. It's worth the money to not have lost all that hair from the aggravation. ;-)
Mic
MicJustMic is offline
post #12 of 20 (permalink) Old 10-01-2003, 11:46 AM
i'm too setting mine and my friends and clients guitars for years, i've never used any jig, i just go by eye, but i dont need to pull the trem to pre-set the saddles.
i really cant see why the trem should be pulled just for the saddles to be moved back and forth.
can't you use your jig with no need to pull the trem?
nuno is offline
post #13 of 20 (permalink) Old 10-01-2003, 11:49 AM
Got an easier way to take all the tension off every string? Pull it, set it, drop it back in and retune, check.
Rich is offline
post #14 of 20 (permalink) Old 10-01-2003, 12:04 PM
i just detune the string slack, move the saddle, then retune the string to pitch.
then i repeat, if needed, with the other strings.
nuno is offline
post #15 of 20 (permalink) Old 10-01-2003, 12:06 PM
Which takes twice as long as just pulling the trem and setting them all at once
Rich is offline
edge pro trem , ibanez bass , intonation tool , locking nut , locking nuts
Edge III tuning stability DsPrestige Tech: Setup, Repairs and Mods 5 04-04-2012 05:47 AM
Edge 3 Tuning problem!!! prydogga Tech: Setup, Repairs and Mods 30 06-26-2010 10:10 AM
Edge pro tuning help! HeadCaseChris Ibanez JEM, UV, JS & Other Signature Models 16 03-06-2010 11:15 AM
WTD: Edge Pro tuning screw. deenkarim Classified Ads: Guitars and Gear 4 02-23-2007 07:44 PM
edge tuning problem - edge tuning problem johank Tech: Setup, Repairs and Mods 1 10-03-2001 09:30 AM
