My Ibanez Custom Model - what would yours be? - Page 2 - Jemsite
post #16 of 71 (permalink) Old 09-15-2001, 11:15 PM
-Jem style, Mahogany, neck thru body with a birdseye maple neck and monky grip.
-PRS style lower horn upper fret access indent
-Mother of Pearl binding on body, neck, and headstock
-Jumo Frets
-Lo Pro Trem
-Tone Zone bridge, Fernandes Sustainer Neck, HS-3 middle
-No pickguard
-Ebony board with abalone and mother of pearl vine inlay
-Flamed maple top with trasparent, dark blue sunburst with matching headstock.
-5 way toggle switch (split 5 wiring).
-Volume knob, tone knob, push/pull sustainer intensity knob, and a sustainer on/off switch
-Petrucci arm cradle
I think that would break a couple of rules, though.
Vai is God is offline
post #17 of 71 (permalink) Old 09-16-2001, 11:14 PM
7 string rg body mahogany w/quilted maple top and
white binding on the body black stained
duncan jb in the bridge and jazz in the neck
lo pro edge of course
reverse headstock ebony fretboard no inlays and white binding
black hardware
vol and 3 way switch
nice and simple
RGA7620 is offline
post #18 of 71 (permalink) Old 09-16-2001, 11:21 PM
Radius Series Body (7 string format if there's such a thing)
XL wizard neck (7 string)
Ebony fretboard
Bubinga strip
Jumbo frets
NO inlays. (God, I love blank boards!!!)
Double Edge system
lo-pro trem - (Powder finish)
5 way switch
1 volume, 1 tone
HSH config. - Air Notron 7, Evo 7 single, PAF Pro 7.
Tilted Headstock
Custom finish. (probably full pearl black or QM top in Transparent blood red finish... YUM!!!)
Killer axe... :biggrin:
(Edited by Spiral Acid at 11:26 pm on Sep. 16, 2001)
Spiral Acid is offline
post #19 of 71 (permalink) Old 09-16-2001, 11:23 PM
IBANEZ!!!! DO YOU SEE THIS!!!!
WE WANT MORE MOHAGANY!!!!:bash: :silly::shoot::loco:
Noodles is offline
post #20 of 71 (permalink) Old 09-17-2001, 11:51 AM
yep, more mahogony, definetly!
7 Dying Trees is offline
post #21 of 71 (permalink) Old 09-19-2001, 07:45 AM
Yeah!
More mahogany and LESS FRILLS!!!!
nuno
nuno is offline
post #22 of 71 (permalink) Old 09-19-2001, 07:53 AM
540 pII Custom
540 pII shaped mahogany body, oil finished (I want to touch the wood!)
Wizard neck, maple/rosewood
24 jumbo frets, last 8 scallopeds
Lo-Pro Edge, black w/ double inserts (for the U-bar, if you want)
Gotoh tuners, black
EMG 85 at the bridge, direct mounted on wood
1 volume pot, SdGr styled
no inlays
no pickguard
no truss-rod cover
tilted headstock, black w/ white logo
AANJ
Jem styled tilted-jack
BackStop system
nuno
ps: Congrats Joten! But why a TRS????
nuno is offline
post #23 of 71 (permalink) Old 09-19-2001, 08:50 AM
i've been rethinkning mine and the ultimate would be :
body and neck
mahogony or Koa s style chambered or semi acoustic body (koa looks so nice)
mahogony neck with ebony fretboard
french polished finished
7 string guitar
Magnetic pickups and electronics
coilsplitting humbuckers in the neck and bridge
individual tone and volume controlsfor both pickups
'kill' switch (a la johnny greenwood)
phase reverse switch for when both pups are on (a la peter green)
3 way les paul style switch
'acoustic' pickups and electonics
piezo in the bridge (double edge)
condenser microphone mounted inside the body
blend control for the mic and piezo
individual volume and tone controls for the above
other electronics
sustainiac
contact pickups in the neck
midi controllable switching for all functions
three outputs (magnetic, 'acoustic' and contact pickups)
other (going a bit sureal here)
a huge manual
batteries that never die
a case with a built in amp and fx that could replace my rack
and most of all i would like it to be free because it sounds like it would cost a bit
one less than none is offline
post #24 of 71 (permalink) Old 09-20-2001, 09:56 AM
mine would be..
-RG body with figured maple top(natural finish)
-Ebony fretboard with triangular blacklip mother of pearl inlays..mmmmm
-lo pro edge..gold hardwaresss
-Jumbo frets
-air norton on the neck and tone zone on the bridge..coil splitting
Kelv is offline
post #25 of 71 (permalink) Old 09-23-2001, 12:06 AM
The thing i think'd be interesting for any guitar company to toy with would be seperate on/off toggles for each pickup. *Think of the possibilities!
* Joel
Whatson is offline
post #26 of 71 (permalink) Old 09-26-2001, 07:00 AM
To add to the "mahogany" list, here's mine:
Body
- UV body style, Mahogany with slightly wider cutaway
- Stained blue finish
- AA Neck Joint
Neck
- UV Neck, oiled
- XL Scale
- Matching finish headstock with only the Ibanez "I" on it.
Electronics
- Stop Tail Piezo (PowerBridge)
- Bridge: EMG-89, Middle: EMG-SA, Neck: EMG-89, both 89's wired for coil tap, all direct-mounted.
- Single, angled output jack
- Single logarithmic volume control.
- 5 Position switch UV style.
Extra's
- DiMarzio straplocks or whatever they are called
- Strap matching body finish
- 10 Private guitar lessons from John Petrucci.
MadKeithV is offline
post #27 of 71 (permalink) Old 09-26-2001, 08:21 AM
Mine of course would be:
JS body w/ lions claw. Either Basswood, Ash, or Alder. Two humbuckers with the coil split for single coils.
Some kind of blue finish with a clear pickguard. Lo Pro Edge. 22fret all maple neck with the option of getting a 24 fret neck. Same frets found on a JS. Neck would be the same measurements as a Wolfgang and of course unfinished like a Wolfgang. AANJ.
Basically a combination of a JS, Jem and Wolfgang
Scott 74 is offline
post #28 of 71 (permalink) Old 02-24-2002, 06:12 PM
Old style 7 string Sabre S5407 with Double Edge trem and the obligatory KJG Mod......
Sevenstringer is offline
post #29 of 71 (permalink) Old 02-24-2002, 07:41 PM
Alright, take the RG 3120 and add.......well we will just leave it at that.
Given to Fly is offline
post #30 of 71 (permalink) Old 02-24-2002, 10:46 PM
Ibanez already built mine - it's the RG7CST - just wish I could find one for sale... *Flamed maple top, mahogany body, maple neck, ebony board with no inlays, Double Edge, Dimarzio pups... *Only thing I'd change is I'd a single coil in the middle and put a push/pull on the tone to split the neck humbucker... *
rlintz is offline
aanj neck , abalone binding , abalone dot inlays , abalone dots , abalone vine , air norton , air norton neck , alder body , alternate tuning , alternate tunings , angled jack , birdseye maple neck , black headstock , body shape , bridge pickup , bridge pickups , bubinga neck , caparison guitars , chrome hardware , chrome jem , coil split , coil splitting , coil tap , condenser mic , cosmo black hardware , custom guitar , custom ibanez , darren wilson , dimarzio breed , dimarzio chopper , dimarzio evo , dimarzio evolution , dimarzio paf , dimarzio paf pro , dimarzio pickup , dimarzio pickups , dimarzio pups , dimarzio strap , dimarzio tone , dimarzio tone zone , dimarzio virtual paf , direct mounted pickups , dot inlay , dot inlays , double edge bridge , double edge pro , double edge trem , ebmm silhouette , ebony board , ebony fingerboard , ebony fret board , ebony fretboard , ebony neck , edge bridge , edge pro bridge , edge trem , equipped guitar , evo bridge , fernandes sustainer , fixed bridge , flame maple , flamed maple , fret aanj , fret aanj neck , fret access , fret board , fret neck , gotoh tuners , hardtail bridge , headstock overlay , jack socket , jackson soloist , jem neck , jem pbk , john petrucci , jumbo frets , les paul , les pauls , lock nut , locking tuners , magnetic pickups , mahogany body , mahogony body , maple binding , maple fret , maple fretboard , maple neck , master tone , matic bridge , mini toggle , monkey grip , mounted pickups , neck humbucker , neck joint , neck pickup , neck pickups , neck position , neck scale , neck thru , neck thru body , norton neck , paf pro , paf pro neck , paf pro pickups , pickup cover , pickup switch , pickup switching , piezo system , pro edge , pro neck , pro pickups , pull tone , pyramid inlay , quilted maple , reverse headstock , reversed headstock , rosewood board , rosewood fingerboard , rosewood fretboard , schaller strap locks , seymour duncan , seymour duncan custom , seymour duncan jazz , shawn lane , sperzel locking , sperzel locking tuners , stainless frets , stainless steel frets , steel frets , strap lock , strap locks , strat style , string thru body , sunburst finish , super wizard neck , swamp ash , toggle switch , tone zone , tone zone bridge , tung oil , tuning system , upper fret , upper fret access , viper neck , virtual paf , walnut neck , wizard neck profile , zone bridge
NGD Ibanez J Custom RG2-TB (Neck Thru Model) IbanezDaemon All Other Guitars (including Prestige) 31 08-26-2012 03:21 PM
WTB IBANEZ J CUSTOM MODEL IbanezDaemon Classified Ads: Guitars and Gear 0 03-22-2012 04:44 PM
FS ibanez custom paul gilbert model sunny_hkband Classified Ads: Guitars and Gear 4 01-11-2011 12:10 AM
If you had an Ibanez custom/signature model IBNZ_RG All Other Guitars (including Prestige) 4 01-02-2011 08:04 PM
Ibanez Usa Custom strange model Kurt76 All Other Guitars (including Prestige) 12 06-13-2006 06:21 PM
