My RG520 has the wrong neck!!!!!!! - Jemsite
post #1 of 9 (permalink) Old 09-03-2002, 09:41 PM Thread Starter
I finally took the neck of my 520 to see the date on the neck joint which is by the way, april 16, 2001(Im hoping the guitar was actually completed on my birthday, april 16th is also the day I bought it in 2002), anyway I was a little surprised to see the stamp on the neck joint that sai ERG 570 and Im wondering is this supposed to be like this? I havent had any problems with the neck and I know they are identical, but you think they would designate them differently. Is there a difference for example in the quality of the old 700 series necks and the 500 series? ALSO Just to add, and maybe rich can help me with this, once I took the neck off when I use the whammy bar the neck pops a little bit. The bolts are as tight as they go, and the necks on perfectly straight. Do I just need to let the neck settle? after ive taken it off?
sniperfrommars1 is offline
post #2 of 9 (permalink) Old 09-03-2002, 09:51 PM
All the 520's have 570 necks.
musicdr is offline
post #3 of 9 (permalink) Old 09-04-2002, 05:11 PM
The only difference between a 5 and a 7 series is the 7 series has sharkfin inlays. Necks can creak a little with whammy use, it's normal.
Rich is offline
post #4 of 9 (permalink) Old 09-04-2002, 05:21 PM Thread Starter
well it used to creak for like 2 seconds, and then wouldnt at all. Now it does it more frequently. Why does it creak? is it moving? Is there ANYTHING I can do to stop it. Its just annoying. I dont hear it through the amp, and I NEVER have to tune this guitar. it stays in tune ridiculously well. But I dont want it to creak
post #5 of 9 (permalink) Old 09-04-2002, 05:44 PM
You either don't have it as tight as you think, or you have it too tight. Try adjusting a little
Rich is offline
post #6 of 9 (permalink) Old 09-04-2002, 06:48 PM Thread Starter
Too tight????? Dear god rich Too tight You can actually get them too tight???? My rg custom never did this, and I screwed it in with a powertool
post #7 of 9 (permalink) Old 09-04-2002, 08:45 PM
I use a Dewalt, doesn't mean I couldn't tighten it more with a screwdriver if I wanted to risk a strip The point was, either tighten it a little more, or loosen it, just to see if it made a difference
Rich is offline
post #8 of 9 (permalink) Old 09-04-2002, 09:17 PM
this may sound stupid, but remove the neck, hold it in place with all your strength (i mean REALLY hard) and then put the screws (maybe some one else can do it while you press).
caprile is offline
post #9 of 9 (permalink) Old 09-04-2002, 11:08 PM
dewalts rule
rich
rty13ibz98 is offline
neck joint , sharkfin inlays
RG520 project, wizard II neck, and Edge III don't fit. 22629 All Other Guitars (including Prestige) 2 12-09-2008 03:18 AM
RG520 / RG570 Neck Finish TripleFan All Other Guitars (including Prestige) 0 06-18-2006 07:14 AM
Neck angled wrong on 3120? TheJazzTerminator Tech: Setup, Repairs and Mods 2 06-02-2006 07:16 PM
neck evo in 7v installed wrong from the factory? - i think t shawn Tech: Setup, Repairs and Mods 16 05-31-2004 04:45 PM
Something wrong with my 2027 neck - Finish on back beginning Gresh Tech: Setup, Repairs and Mods 6 04-23-2002 08:58 AM
