My S2170 has some problems...can they be fixed and would it be worth it? - Jemsite
post #1 of 4 (permalink) Old 02-14-2011, 10:13 AM Thread Starter
Ok, so I have an S2170FW. I dragged it out of its case after nearly a year last night and sat down to play.
At first, I got a real sense of "Why did I ever retire this guitar, its awesome"
But after playing it for a while I realised it has some problems that diminish its potential.
The first of them is the non-matching radius of the saddles and neck. I know I can get this fixed.
THe other problem is somewhat less certain. For one thing, it really doesn't sustain that well. My S7320 is a cheaper non-prestige guitar and sustains longer. I look at them and the neck on the 2170 is higher out of the pocket than the 7's is, which I know can cause that a little, but to that extent?
It also seems to have a more rounded, less defined attack, acoustically, than my 7. Looking at the neck, it seems theres absolutely no back angle in the pocket. I know on an acoustic that can make the tone muddy compared to one with a small angle, is it the same with this guitar? Would lowering the neck pocket mean a little more back angle and would that help the sound?
Edit: Rich, if you happen to stumble on this, any ideas?
GuitarBizarre is offline
post #2 of 4 (permalink) Old 02-14-2011, 10:26 AM
Re: My S2170 has some problems...can they be fixed and would it be worth it?
Where in the Uk are you based? You might want to look up Max Cottam.
IbanezDaemon is offline
post #3 of 4 (permalink) Old 02-14-2011, 03:16 PM
Reviews: 120
Shim your saddles to closer match the radius of the neck. I use slivers of emery paper.
To increase sustain and brighten the tone get a brass big block for your trem. Your guitar has an Edge/Lo Pro doesnt it?
LonePhantom is offline
post #4 of 4 (permalink) Old 02-14-2011, 03:55 PM Thread Starter
No, Original ZR.
Yes i fixed my whammy problems! Glados Tech: Setup, Repairs and Mods 3 01-23-2008 12:32 PM
AT300 vs S2170 Prestige jforsythe All Other Guitars (including Prestige) 2 08-23-2007 11:52 AM
S2170 Ahole All Other Guitars (including Prestige) 6 07-28-2006 08:55 PM
S2170 finish question. 70Seven All Other Guitars (including Prestige) 5 03-10-2006 02:28 PM
S2170 NeglectedField All Other Guitars (including Prestige) 4 02-11-2006 12:03 AM
