A neck question - Jemsite
post #1 of 2 (permalink) Old 05-12-2007, 10:06 PM Thread Starter
A neck question
I've been trying to search out this answer and haven't found anything concrete so I decided to break down and ask.
Does an RG520 use the same neck as an RG1570? If not, what are the differences?
Thanks and pardon my ignorance.
Homeless is offline
post #2 of 2 (permalink) Old 06-10-2007, 09:21 PM
Re: A neck question
Same neck on rg520, 550 and 570. Usually when you remove the neck from any of those models, you will find either RG550 or RG570 stamped on it regardless which model guitar you have. #2 after the neck stamp denotes Wizard II profile. Most are Wizard profile. Some RG470 years actually have RG550 necks on them. The newer "prestige" RG models are also likely to have a neck stamp that does not match the model(but agin, the necks are the same).
albee1952 is offline
Jem7PBK - Question about the neck Martijn Ibanez JEM, UV, JS & Other Signature Models 3 01-03-2007 08:04 AM
Wizard II Neck Nut Replacement Question Dark Alone Tech: Setup, Repairs and Mods 10 09-13-2006 09:22 AM
Painted neck? Sanded neck? Drache713 All Other Guitars (including Prestige) 28 12-24-2005 11:45 PM
Neck profiles question from an Ibanez newbie Anonymous All Other Guitars (including Prestige) 3 05-06-2004 08:26 AM
Different Jem's = Different Neck profiles? - a question rega jem7vwh Ibanez JEM, UV, JS & Other Signature Models 13 01-31-2001 03:14 PM
