Need advice on RG 2570 project - Jemsite
post #1 of 9 (permalink) Old 11-06-2011, 08:56 AM Thread Starter
I bought a beautiful custom painted RG 2570 body and need some advice. My plan is to buy another compatable guitar. Then strip all the parts off it except the body, the pups (I want to pick my own pups), and a few other things. Then sell the donor body to recoup some of my expenses.
I need to know which models of RG I should be looking for to get good compatable parts.
I've also read that the necks got thicker as the years went on. I'd prefer a thinner neck like the Original Wizard or the Super Wizard rather than the Prestige neck or the Wizard II. Am I correct in thinking that they will fit the 2570?
As for other parts like bridge, tuners, etc. are some years and models better than others? Is there anything I should stay away from?
Thanks!
MuddyWolfJohnson is offline
post #2 of 9 (permalink) Old 11-06-2011, 10:58 AM
Re: Need advice on RG 2570 project
Is she one of the earlier 2570's that came with the Edge pro???
IbanezDaemon is offline
post #3 of 9 (permalink) Old 11-06-2011, 04:06 PM Thread Starter
I'm waiting on delivery now. Here's everything I know about it:
http://www.ebay.com/itm/140626679000...84.m1438.l2649
post #4 of 9 (permalink) Old 11-06-2011, 04:21 PM
That is sweet!!! Edge Pro on that originally and Super Wizard Prestige neck.
post #5 of 9 (permalink) Old 11-06-2011, 04:49 PM
RGTFanatic's Avatar
Beautiful....and Daemon is right on the money!!! You want an Edge-Pro and a '97-'04 Super Wizard neck.
The '03 & '04 necks (original to that body and were called the SW Prestige) are 1mm thinner @ the 12th fret, but any Super Wizard will work perfectly well. Just make sure whatever you buy has a 56mm heel.
Ryc
RGTFanatic is offline
post #6 of 9 (permalink) Old 11-06-2011, 05:03 PM Thread Starter
Thanks guys! I'm going to call her Vina.
and this is Orion (as in http://www.youtube.com/watch?v=G9iHAJIbdj4)
post #7 of 9 (permalink) Old 11-06-2011, 05:14 PM
RGTFanatic's Avatar
Great names!!
The only thing I want to call my customs.....is Done!!....LMAO!!
post #8 of 9 (permalink) Old 11-06-2011, 05:14 PM
Holy!!! Beam me up!!
Any other ideas on the project yet???
post #9 of 9 (permalink) Old 11-06-2011, 07:23 PM Thread Starter
I'm still trying to figure it out. I actually set out to buy a Saber. I like the neck so much better on my rebranded neck-thru (a 1989 HM Squier that was Fender's response to the Japanese guitars) that when I picked up my Strat the fat neck just didn't feel right anymore. I was going to buy an SSH Saber and try to get some Strat type tones from it. But when I saw Vina I had to have her. I might buy a Saber later.
I have figured out a few things. I know the backing plates of both guitars are going to be covered with pics of Vina and the Orion slave girls. I haven't decided on pups yet (most likely REAL Dimarzios of some kind) but I know how I want them wired. Orion has Seymours (Pearly Gates N, Hot Rails M, and Full Shred B) that have been wired for out of phase and coil tapping. Hence the 5 little switches.
I use the out of phase flavors often but I never use the coil splitting. And the switches can be a bit confusing. So I'll be doing something much simpler with Vina. I'm going to add a 3rd knob and assign each to a pup as volumes.
Then I'll hide the 5 way switch hole behind something like this:
So instead of a pickup selector I'll adjust the volume knobs like an eq dialing out what I don't want to hear. All the way down will be the off position of each pup. Two of the knobs will have a push/pull for out of phase. So I'll have 3 out of phase flavors (M oop / B oop / M&B oop). And all 3 pups can be blended together for the best tones. This will give me everything I like about Orion's wiring but be much simpler.
rg 2570
Project RG 550! Need some advice on ideas! mgk321 Pickups & wiring 9 03-11-2011 12:19 AM
Project advice wanted boberfet6789 All Other Guitars (including Prestige) 14 01-24-2011 04:42 PM
First Tung Oil Project: Advice bdk Tech: Setup, Repairs and Mods 2 03-18-2009 12:41 PM
Project Guitar Need Advice! wandereruk05 Tech: Setup, Repairs and Mods 0 05-21-2008 06:21 AM
Working on a project...BSB/G Vandenberg?! - Need advice and ScottM All Other Guitars (including Prestige) 20 06-16-2002 08:25 PM
