need help to drop a whole step - Jemsite
post #1 of 17 (permalink) Old 05-29-2006, 09:03 PM Thread Starter
everytime i drop a whole step i can't get the trem parrallel.do i need to add more springs?or a heavier gauge?wanna set it up for motley stuff and leave my epi lp standard.thanks experts
new to locking guitars(rg2550e)
jukes is offline
post #2 of 17 (permalink) Old 05-30-2006, 10:59 AM
Re: need help to drop a whole step
You can adjust the screws that hold the plate where the springs are attached (the screws that go in the body).
For better info and pics check Rich's site: http://www.ibanezrules.com/tech/setup/angle.htm#EP
Aris_T is offline
post #3 of 17 (permalink) Old 05-30-2006, 01:09 PM Thread Starter
i did that.but the screws only go out so far before you get to the end of the threads.so i took out a spring and it didn't have enough pull on the springs going the other way.i know mick drops a whole step with a floyd to get the meaty growl,i just wanna figure it out.
jukes is offline
post #4 of 17 (permalink) Old 05-30-2006, 11:46 PM
ScottB's Avatar
If you're using .009 strings and tuning down 1 step, Try 2 springs in an arrow pattern.
ScottB is offline
post #5 of 17 (permalink) Old 05-31-2006, 04:50 AM Thread Starter
tried that and it isn't enough pull so i run out of threads on the trem screw.
jukes is offline
post #6 of 17 (permalink) Old 05-31-2006, 11:08 AM
I imagine that you use 3 springs, isn't it so?
I use .010 gauge strings, 3 springs in an arrow pattern, tune down 1 step and don't have any problem. Maybe you should try the different gauge.
Aris_T is offline
post #7 of 17 (permalink) Old 06-01-2006, 10:42 PM Thread Starter
thanks aris!i will up a gauge to tens then drop a whole step.thanks>it can be done!
jukes is offline
post #8 of 17 (permalink) Old 06-01-2006, 10:50 PM Thread Starter
is it like an arrow like this > or this< with the bridge on the right
jukes is offline
post #9 of 17 (permalink) Old 06-01-2006, 11:21 PM
jaxadam's Avatar
I have plenty of guitars around here that are dropped, and I always use three springs parallel, sometimes 4 springs, with 11's.
I have one guitar in drop b with 12's and 5 springs, just to give you another idea.
jaxadam is offline
post #10 of 17 (permalink) Old 06-02-2006, 02:09 AM
It's like this < (with another spring in the middle).
Aris_T is offline
post #11 of 17 (permalink) Old 06-03-2006, 10:47 PM Thread Starter
thanks guys i will get a set of 10's and try it out on my days off
jukes is offline
post #12 of 17 (permalink) Old 06-03-2006, 11:50 PM
jaxadam's Avatar
I think you'll have better luck with 11's.
jaxadam is offline
post #13 of 17 (permalink) Old 06-04-2006, 10:04 AM
jaxadam's right. You'll probably have better luck with 11's. I tried 10's because I was really used to 9's and didn't want to go far. If I did now, I would go for 11's.
Make sure you adjust the bridge properly (you will see it rising!!).
Good luck!
Aris_T is offline
post #14 of 17 (permalink) Old 06-05-2006, 02:27 AM Thread Starter
why would you go with 11's?instead of tens?did tens not work out well?and hoe many springs did you use with 11's
jukes is offline
post #15 of 17 (permalink) Old 06-05-2006, 09:03 AM
I would for with 11's because I got used to 10's (I play my acoustic with 12's) and don't care anymore about the bigger gauge (it doesn't hurt!). 10's worked great, but IMO the bigger the gauge, the bigger the sound!
I wouldn't use more the springs (I think 3 are ok), but a friend who uses a C tuning with 11's, uses 4 springs (parallel attached). You could experiment with the tension. It's up to you.
Aris_T is offline
gauge strings
trying to set up jem on drop C evolusean Tech: Setup, Repairs and Mods 9 08-08-2005 02:39 AM
Strings for drop C tuning Wound All Other Guitars (including Prestige) 12 10-28-2004 12:54 PM
Once again..Key signature problems.....Am i stupid? Help!! Swirly Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 25 08-27-2003 10:02 AM
JEM77GMC Mint except for 1/2" ding!!! - ...step by step guid Dean Southcombe Tech: Setup, Repairs and Mods 10 09-04-2001 12:50 PM
