Need help finding AX7221 parts - Jemsite
post #1 of 5 (permalink) Old 09-26-2005, 02:29 PM Thread Starter
I've been to WD, Warmoth, Allparts, and StewMac (so far), but no one seems to make a replacement bridge that will fit. Anyone know where I can find something that will fit this in black? I don't mind drilling different mounting holes, but it would have to fit the same dimensions.
noodlesatf is offline
post #2 of 5 (permalink) Old 09-26-2005, 03:19 PM
Re: Need help finding AX7221 parts
Don't know if it would fit, but:
http://www.hipshotproducts.com/7string/7string.htm
I just bought an 8 string bridge from them and it's nice.
Serratus is offline
post #3 of 5 (permalink) Old 09-26-2005, 05:02 PM Thread Starter
Hipshot makes great stuff. Unfortunately, the bridge on the AX7221 is 3.5" x 2". Really oversized.
post #4 of 5 (permalink) Old 09-26-2005, 05:09 PM
I have an AX7221 and have noticed that the bridge routes doesn't match any aftermarket replacements that I've seen. I think you'd probably have better luck trying to find a place that does metal finishing and just have the original refinished.
I measured my AX7221 bridge and I don't think the Hipshot 7-string bridge is wide enough to cover the original screw holes. You could try the "SB_5100-003, 7-String Non-Tremolo Guitar Bridge, Black, Steel Saddles, 2-1/2" String Spacing" at http://www.allparts.com/categories.php?cat_id=403&cat_name=7%20&%2012%20ST RING%20BRIDGES. The string spacing is right and it looks like it might be wide enough, but I'd really contact them for more precise measurements before I'd order it.
Good luck.
thomascmurray is offline
post #5 of 5 (permalink) Old 09-27-2005, 06:02 PM Thread Starter
Thanks guys. I was figuring I had to refinish myself, but it was worth a shot.
string bridge
S470DXQM need helping finding parts snarph All Other Guitars (including Prestige) 4 01-28-2013 10:40 PM
need help finding UVMC777 PARTS joeydego Ibanez JEM, UV, JS & Other Signature Models 17 03-02-2011 02:25 AM
REALLY Need help finding electronic parts for rack EQ Darin Off-topic / Miscellaneous 3 11-29-2008 08:47 AM
7 project for the summer...need help on finding parts! Smitty All Other Guitars (including Prestige) 4 05-22-2007 10:55 PM
Finding a prestige neck and misc parts Homeless All Other Guitars (including Prestige) 9 04-03-2007 03:59 AM
