need help ! ibanez prestige bargain. is it worth the money? - Jemsite
post #1 of 17 (permalink) Old 04-29-2015, 05:39 PM Thread Starter
Hello fellow jemmers
So i looked on the internet and came acros an interesting looking guitar for sale
It turned out to be an s1220 prestige made in japan.
I talked to the guy who has it for sale and he wanted to sell the guitar at a price of €375euros.
But theres a tiny problem with it (or big) i dont know for sure. It has a little crack in the neck . nothing big at all but when a lot of pressure is applied on the neck. he told me that decreases the value of the guitar (obviously)
But what i want to know is How much the price goes down?
Or is it even worth it?? . i hope you guys know something or can give me some information.
Thanks!
fatalisk300 is offline
post #2 of 17 (permalink) Old 04-29-2015, 05:46 PM
Re: need help ! ibanez prestige bargain. is it worth the money?
Do you have pictures of the crack? If it's not a structural issue, it's probably a good deal.
Drew is offline
post #3 of 17 (permalink) Old 04-29-2015, 05:54 PM Thread Starter
I do have some pics but i dont know how to post them on here (im new just made this account like 10minutes ago haha)
Anyway. It doesnt look like anything big. And the crack only shows up with big amounts of pressure. Maybe this could be fixed easily.
But what should i bid maybe from €375 to €300 or €250?
Also fast replys! Thanks
post #4 of 17 (permalink) Old 04-29-2015, 07:47 PM Thread Starter
I could get it for €275
Thats a really good deal i guess
post #5 of 17 (permalink) Old 04-29-2015, 08:30 PM
RGTFanatic's Avatar
Can you post a link to the pictures. It could be a great deal, but without know where the crack is- it's impossible to help.
If you cannot post the link, you can send it to me in a personal message....
RGTFanatic is offline
post #6 of 17 (permalink) Old 04-29-2015, 08:37 PM Thread Starter
Okay
I can send the pics through email tho .
There no link for some reason
post #7 of 17 (permalink) Old 04-29-2015, 08:39 PM
RGTFanatic's Avatar
click my name and you'll see a link to "send a personal message". You can send the link through there...
post #8 of 17 (permalink) Old 04-29-2015, 10:29 PM
RGTFanatic's Avatar
I got your email.
Fortunately, these cracks are only slightly worse than what is typically found on older Ibanez guitars with a scarf joint. You can repair it yourself easily and cheaply while sitting at home. You'll only need some thin cyanoacrelate (sp?) A.K.A. superglue and a couple grades of sandpaper.
Here are the pics for everyone to see:
post #9 of 17 (permalink) Old 04-29-2015, 10:41 PM Thread Starter
Doesnt sound to hard to repair that.
And why are those common on older guitars btw?
So is it actually worth buying this guitar.
And thanks so much guys for all your help!
post #10 of 17 (permalink) Old 04-30-2015, 12:03 AM
RGTFanatic's Avatar
I don't know what would be a normal price for your market, but at around the $300 exchange for 275 euro's I would buy it. Of course I know I can do the needed neck repair. You still have to figure that into your decision and how much your time is worth.
The reasons for nut joint cracks vary a bit. My guess is that the one your looking at fell onto the back tip of the headstock at some point. If you buy it, come back here so we can help you fix it up right....
post #11 of 17 (permalink) Old 04-30-2015, 07:41 AM
Because the necks were so thin, with the 2 screws going through the wood like that, over a period of time, with neck warping and all due to weather changes, cracks do appear. I've never personally seen a neck crack on any of my older Ibbies (I had a 1993 RG550, and I currently have a 1990 RG560, neither of which had any neck issues.)
MatiasTolkki is offline
post #12 of 17 (permalink) Old 05-01-2015, 04:36 PM
Reviews: 3
I had one about 5 times as big on an RG550 I bought. Took it to my guitar guy and you can't tell the difference. Either way the guitar played fine so I don't think you have too much to worry about.
finstah is offline
post #13 of 17 (permalink) Old 05-07-2015, 08:03 AM
The S1220 are great guitars!!!! That crack does not scare me... If everything else is OK with the guitar (straight neck, good frets etc), I would go for it.
One tip I would give for the repair, is to remove the strings and the nut from the guitar before applying the glue.
remove also the little washers that are bellow the two screws at the back of the neck.
You do not want to glue all this stuff toghether. Wait for the glue to cure before sanding with 500 or higher (thiner) sandpaper to smothen out the glue residue.
jazzedout is offline
post #14 of 17 (permalink) Old 05-07-2015, 08:43 AM
Hmmm so if hole-crack size is not an issue how would you classify :
PVA (white wood glue) vs CA (super glue) vs Polyurethane vs Epoxy?
PVA has worked wonders for me, for any wood project I did, while Epoxy has performed fantastic for anything but wood. I started losing faith in CA as the materials it can bond become fewer and fewer. Polyurethane has also worked fantastic for concrete, walls, ... (and of course ... fenders)
panix is offline
post #15 of 17 (permalink) Old 05-07-2015, 09:13 AM
RGTFanatic's Avatar
I think the crack size is very important. It determines which product I'll use.
When it comes to guitars my adhesive options are- Hide glue, CA, or titebond wood glue. Each has it's strong points and weak points. For very thin cracks such as these- CA is the best choice because it can wick into the full depth and length of the crack before curing.
I don't use "over-the-counter" super glue. I only use stewmac's #10 (thin) CA. I don't know if standard superglue and stewmac's CA are the same or not, but I've gotten much better bonds with the CA.
Ibanez JS24P? Worth it or save my money? Monsta-Tone Ibanez JEM, UV, JS & Other Signature Models 14 04-05-2014 10:01 PM
Is the JEM 7V worth the money? Markzi Ibanez JEM, UV, JS & Other Signature Models 23 11-01-2011 06:26 AM
worth the money? humpy Ibanez JEM, UV, JS & Other Signature Models 10 11-29-2009 04:04 AM
BEST ibanez prestige guitar for your money? NeoShred X All Other Guitars (including Prestige) 14 07-30-2005 01:17 PM
pod or pod pro - which is worth the money more? shapshankly Gear, Equipment, Recording & Off Topic 7 12-21-2000 02:21 AM
