need help with a problem with my tremolo! - Jemsite
post #1 of 10 (permalink) Old 09-04-2004, 11:32 AM Thread Starter
i have a rg2620 saphire blue ibanez with edge pro saddle.
The problem is that the tremolo arm is loose so that its hard to use the tremolo and i'm not sure if something is going to break (the saddle or the arm) if i continue to use it... it's just like if the hole in the saddle for the arm was too wide... the problem occured some time ago and i changed the teflon washers and that helped but now it's loose again and i don't think the teflon washers are ment to be replaced every couple of weeks...
what should i do? new teflon pieces again so that i can play a couple of weeks again with the tremolo working properly?
Omso is offline
post #2 of 10 (permalink) Old 09-04-2004, 07:02 PM
Kontalonis is offline
post #3 of 10 (permalink) Old 09-04-2004, 11:14 PM
is it loose as in the arm swings around or does it feel detatched from the bridge?
bobojem is offline
post #4 of 10 (permalink) Old 09-11-2004, 08:46 AM Thread Starter
It feels detached from the bridge... it's supposed to swing around right?
is the nailpolish thing going to help if the arm feels detached? i don' t care how much it swings... i just want it to feel like it's part of the bridge and not "wobble" in it's hole...
i'm just having doubts about putting nail polish on any of the parts of my guitar... i mean... is it really what everyone does? no better way to do the job? can the nail polish for example damage anything?
Omso is offline
post #5 of 10 (permalink) Old 09-11-2004, 12:59 PM
are the white rings on the tip visible?
Wis Redz of Silvanost is offline
post #6 of 10 (permalink) Old 09-11-2004, 02:18 PM
The trem arm holder might be loose. Yu'll have to take the trem off and look underneath. There is a nut that holds it secure.
CrossingStar is offline
post #7 of 10 (permalink) Old 09-12-2004, 08:11 AM Thread Starter
no the rings aren't visible... the arm is how it should be... maybe i'll have to take the tremolo off then...
Omso is offline
post #8 of 10 (permalink) Old 09-12-2004, 08:30 AM Thread Starter
i read the tech setup page on jemsite and i found out exactly what i have to do... thanks
Omso is offline
post #9 of 10 (permalink) Old 09-12-2004, 12:26 PM
Let us know how it goes, if you get into trouble or don't feel comfortable doing it then you can always try looking at the how to pull a trem section on ibanezrules.com in the tech area, i used that guide and found it simple enough, kinda hard to break anything really lol
Andelusion is offline
post #10 of 10 (permalink) Old 09-12-2004, 01:07 PM
I think you're refering to the loose arm socket. I've had the same problem before, no biggie. I just took the trem off and screwed the socket tight with the screw on the back of the bridge piece. And yea, let us know how it goes
bobojem is offline
arm holder , trem arm , trem arm holder , tremolo arm
Tremolo Arm Problem!! \Dom/ All Other Guitars (including Prestige) 1 05-18-2012 11:21 AM
ZR tremolo problem Tomm89 All Other Guitars (including Prestige) 17 04-13-2010 02:53 AM
Problem with 03/04 ZR Tremolo lyconxero Tech: Setup, Repairs and Mods 3 01-31-2006 10:09 PM
Lo Pro Tremolo problem Pikaciao Tech: Setup, Repairs and Mods 3 11-13-2005 01:39 PM
tremolo problem.... :( rx Ibanez JEM, UV, JS & Other Signature Models 14 04-01-2005 06:45 AM
