need help with S470 ZR Trem - loose screw - Jemsite
post #1 of 2 (permalink) Old 07-17-2006, 05:44 AM Thread Starter
Hi all, hoping someone could give me advice about the ZR tremolo.
I have a S470, bought new late 2004 that doesn't hold tune properly anymore. What happens is the E, B, G strings hold their tune fine but right after using the trem bar, the D, A & E strings go slightly flat. I took the trem apart and discovered that the mounting screw right next to the trem bar (see pic) is pretty wobbly.
This used to be strung with 9-42 gauge up until 3 months ago when I had 10s put in. Maybe changing to a higher gauge must have worn out the threads cos of the added tension. My question is can I just wrap some teflon tape that plumbers use around the screw so it fits snugly again? Is this a good idea or should I just order a new screw from ibanez?
Oh yea, almost forgot...could adjusting the action height while the guitar was fully tuned up and tensioned have contributed to this problem?
Thanks
Hairp1ck is offline
post #2 of 2 (permalink) Old 07-20-2006, 11:38 AM
Re: need help with S470 ZR Trem - loose screw
Try pulling them out and see if the threads are stripped down. that's more than likely the culprit and if so, should be a cheap replacement. Teflon tape won't offer the tightness that a brand new mounting stud would.
FastRedPonyCar is offline
Replacement for Lo TRS Trem 2 on S470 Leader Tech: Setup, Repairs and Mods 3 01-26-2006 11:19 PM
Trem Screw Replacement The Decay Tech: Setup, Repairs and Mods 3 12-15-2005 06:28 AM
trem arm loose Vai the god of Sound Ibanez JEM, UV, JS & Other Signature Models 5 05-17-2002 09:02 AM
Question about trem post - How tight loose? Triangle Tech: Setup, Repairs and Mods 6 08-08-2001 04:50 PM
I have a screw loose! - LO Pro Edge problem. jem7vwh Ibanez JEM, UV, JS & Other Signature Models 2 03-13-2001 09:23 PM
