Need Opinions on the S2170 Prestige - Jemsite
post #1 of 4 (permalink) Old 12-05-2009, 08:05 AM Thread Starter
I was offered a trade on one of my other guitars for this S2170 ebony swirl but I don't know anything about it. Two weeks ago I just got a RG3120 and am beginning to get acquainted with it. I have zero experience with the "S" series though. The only other Ibanez I've owned and kept was a JS1000.
Is the S2170 a sought after guitar, a dog or somewhere in between?
MJ Slaughter is offline
post #2 of 4 (permalink) Old 12-05-2009, 12:22 PM
Reviews: 10
Cool Re: Need Opinions on the S2170 Prestige
The S2170 is quite frankly a controversial guitar. However, most of the controversity stems from discussions among people who are used to the 90ties S-series guitars, and the S2170 is quite a different beast. It doesn't really help the biased discussion that it was Korean-made, which for some people is a complete heresy (as Prestige = made in Japan).
I have a 2007 S2170FW (Burl Poplar) that I got used about 1.5 years ago.
Overall, the mahogany body resonates well even when played unplugged, and is very comfy. The Dimarzio/IBZ pickups (kinda medium-high output) are better than their reputation I think, but they are definitely not top notch. They sound well in the guitar, good note separation in cords even under high gain. The PAF Pro-ish neck humbucker is definitely my favorite on the guitar for soloing. But if you're into more agressive metal with searing distortion, the pickups will be too weak. The ZR trem is fun I think, very spongy and easy to maintain. Only bummer is that the cosmo black finish might rub off if you don't wipe the hardware clean after playing. The trem rings are super-bad quality coating, every S2170 I have seen had tarnished rings - I polished mine down to the metal, which looks actually decent and is a cheap solution.
The main issue with the guitar for most people is the neck shape and fretboard radius. It's marketed as a Wizard II, but it's different to the one found on current Indonesian-made Ibanez models. It somehow comes across as "beefier", with thicker shoulders. It also has some kind of semi-glossy finish that is different from the regular satin-ish Prestige neck finish.
The fretboard radius is 400mm (less flat than your RG3120, but way flatter than the JS1000). Yet, the bridge's radius is 430mm, resulting in slightly less low possible minimal action. But there are tons of guitars out there with such specs. Just don't expect sub-1mm action and you will be fine. I played around a lot with its action, and I like it now quite a bit. It's low, not as low as on others I play, but low enough (1.2-1.3mm maybe @ 22nd fret). Together with the fatter neck it is refreshing to play - plus very good practice to get your hands strong and flexible .
If you are used to a Super Wizard neck as on your RG3120 (or if you "think" you can only play on a pencil neck), it's not for you. The neck on my S2170FW is the fattest neck in my small Ibanez collection (RG8470F, S540CG).
Also, S2170s were quite overpriced when still in production - the very sexy tops did not really justify that. They are no Team J Craft Prestige (although, that seems to mean something else these days than it used to...), although the fretwork and overall worksmanship on my S2170FW is great. The guitar can scream and purr and sing crystal clear. All it takes is using it for what it can do.
Play one, try it out, if you don't like it, leave it - there are so many other fine guitars around. I personally hang on to mine for the moment.
What kind of trade do you plan?
cm_17 is offline
post #3 of 4 (permalink) Old 12-06-2009, 12:55 PM Thread Starter
Thanks for all the detail cm_17. It's funny that I have one of the thinnest Ibanez necks on my RG3120 but it isn't my preference. Having a thicker neck would be a benefit as far as I'm concerned. I also don't play much metal so lower output pickups is a good thing to me. I would probably like the S2170 radius more because I don't really need the flattest of necks.
The guy wants to trade for my Dean USA Hardtail which sells new for nearly the amount of a PRS, $2600. Unfortunately for me the resale market sucks and the most I might get is $1000-$1200 and it is in mint condition. That guitar is so different from any Ibanez I've ever played. If I hadn't just bought the RG I might take him up on it with a little cash thrown in the deal on his part. Thanks again for all the info.
post #4 of 4 (permalink) Old 12-06-2009, 03:22 PM
Reviews: 10
Keep in mind that these babies went for $1299 street price, which is way too much for what they are.
I got mine in almost pristine used condition for 825. In retrospect, I think that's still the upper limit, as you can get a nice RG1570 for that money. But yea, if you like the beefy neck, sound and feel, and want to get rid of your Dean, then make sure the guy throws in some money into the deal.
cm_17 is offline
Dimarzio Breed in Ibanez S2170? Sledgeman Pickups & wiring 2 06-09-2009 02:18 PM
AT300 vs S2170 Prestige jforsythe All Other Guitars (including Prestige) 2 08-23-2007 11:52 AM
S2170 Ahole All Other Guitars (including Prestige) 6 07-28-2006 08:55 PM
S2170 finish question. 70Seven All Other Guitars (including Prestige) 5 03-10-2006 02:28 PM
S2170 NeglectedField All Other Guitars (including Prestige) 4 02-11-2006 12:03 AM
