Need Some Help With My J Custom - Jemsite
post #1 of 23 (permalink) Old 05-31-2015, 06:20 PM Thread Starter
RTF
Hi Guys,
I was lucky enough to recently acquire a J Custom but don't have much experience with Ibanez guitars and was hoping someone could advise me on a few things. I tend to pick right where the middle pickup is, so I lowered it down to make my life easier. But after lowering it, I noticed that the pickup cover is bending out at the bottom. I was hoping someone could shed light on why that might be happening without me having to take the pickup out and looking it over.
The other thing that I found weird was that inside the pickup cavities, the paint on the inner walls comes off really easily. If I reach in with a Q-tip, it comes out covered in paint. Is that normal?
I'm new to the forum and unfortunately cannot post pics to show you guys what I'm talking about, but I'm looking forward to showing off my guitar when I get the required 10 posts in. In the meantime, any help would be much appreciated!
RTF is offline
post #2 of 23 (permalink) Old 05-31-2015, 06:37 PM
Re: Need Some Help With My J Custom
Shielding paint inside the pickup routs is on top of the clear. If the Q-Tip was went it will remove it, it's not exactly supposed to be durable, just shield.
Rich is offline
post #3 of 23 (permalink) Old 05-31-2015, 06:46 PM Thread Starter
RTF
I see. I just thought it was weird that it came off so easily - the Q-tip was not wet. Nor did I apply a lot of pressure.
Do you have any idea why my pickup cover might be bending out? Thanks.
RTF is offline
post #4 of 23 (permalink) Old 05-31-2015, 07:01 PM
You'll have to post a picture for me to understand what you mean by bending out, but the neck humbucker wire does run under it.
Rich is offline
post #5 of 23 (permalink) Old 05-31-2015, 07:03 PM Thread Starter
RTF
Yeah, I thought it might be a wire causing it. Note sure though - I'll post pics soon as I can. Thanks for the help!
RTF is offline
post #6 of 23 (permalink) Old 05-31-2015, 07:50 PM
RGTFanatic's Avatar
get that post count up man...... we want to see your JC!!!
RGTFanatic is offline
post #7 of 23 (permalink) Old 05-31-2015, 07:54 PM Thread Starter
RTF
I'm working on it
RTF is offline
post #8 of 23 (permalink) Old 06-05-2015, 07:56 PM Thread Starter
RTF
RTF is offline
post #9 of 23 (permalink) Old 06-05-2015, 09:01 PM
Beautiful wood on that one.
No, that is not normal at all, I'd be writing asking for a new cover.
Rich is offline
post #10 of 23 (permalink) Old 06-05-2015, 09:04 PM
Man, that's a stunner. Crazy top!
DaylightDies is offline
post #11 of 23 (permalink) Old 06-05-2015, 09:33 PM Thread Starter
RTF
Thanks guys - the top is really special on this one. Rich, the cover is totally fine until I lower the pickup. Any idea what might be causing this?
RTF is offline
post #12 of 23 (permalink) Old 06-05-2015, 11:13 PM
Reminds me of when you tell the Doctor your elbow only hurts when you move it, and the Dr. tells you not to move it
Rich is offline
post #13 of 23 (permalink) Old 06-06-2015, 02:33 AM
RGTFanatic's Avatar
There's something under the middle pickup that's causing the cover to bow out like that. My guess is that you have the neck pickup wires pinched in hard under there. You'll want to raise it up again if you want to continue to use the neck pup. with that much pressure on the wires, they're going to short out.
BTW.... beautiful guitar man. Is it a JCRG13EM with the square heel?
post #14 of 23 (permalink) Old 06-06-2015, 07:40 AM Thread Starter
RTF
Thanks man - yep that's exactly right. The square heel makes playing the upper frets a bit harder, but I really dig it aesthetically. I guess I'll raise the pickup - hope no damage has been done to the neck pup wire. But this sucks because I hate playing with the middle pup so high. Any ideas for a solution? Thanks for the help guys.
RTF is offline
post #15 of 23 (permalink) Old 06-06-2015, 08:39 AM
stratoskier's Avatar
I'd check to see what the bent part is catching on. As mentioned -- it might just be wires that should be laying in a channel, but aren't settled in there properly.
If it can't be fixed by rearranging something in there, I'd simply cut a small notch/groove in the pickup cover to accommodate whatever it's hitting, or else I'd shave off a few mm's on the bottom of the whole cover using a grinder (or just a sanding block).
Pickup covers also come in different heights, but the colors often don't match perfectly, especially when trying to match up with aged covers.
(Afterthought -- that cover shouldn't come down any lower than the pickup base, so you should be able to diagnose the problem with just the cover and pickup lifted out of the guitar. For some reason, the cover isn't seating on the pickup, so they're mismatched.)
stratoskier is offline
Sell/Trade Rare USA Schecter Custom shop 7 String California Custom jake8773 Classified Ads: Guitars and Gear 0 01-25-2014 05:37 PM
FS: Ibanez J-Custom RG-2, ESP M-II Custom NTB, ships worldwide, free EU shipping kosaq Classified Ads: Guitars and Gear 2 01-02-2010 06:47 PM
FS: Jackson Custom Shop Telly Custom Amber Sunburst one of a kind Ambitot Pu Phang Classified Ads: Guitars and Gear 0 05-02-2008 01:19 PM
