need a template for 540 p tpc pu ring - Jemsite
post #1 of 12 (permalink) Old 05-09-2008, 03:17 PM Thread Starter
i need someone that has one to please send me a template as im trying to restore my 540p triplecoil and lost my pu ring in moving, so i need size thickness and a template of your pu ring so i can get one made as these are to hard impossible to find. I would really appeciate it. thanks
mextremist666 is offline
post #2 of 12 (permalink) Old 05-09-2008, 06:03 PM
Re: need a template for 540 p tpc pu ring
Fretsonthenet.com make me a 7 string version of this tripple coil ring. He should be able to make you a copy of the original 6 stringer version.
It's just a humbucker and a single pup combined in one. Send him the dimarzio specs (if you going for that route) you can find on their website.
I have original triple coil laying around if you need specs.
Jemmm is offline
post #3 of 12 (permalink) Old 05-09-2008, 10:31 PM Thread Starter
i did talk to the guys at fretson the web, he was needing the sizes of the old one, thickness , hole position ect. but i dont have the old one , he said someone that has one might be able to help me on this site, with either dimensions , or template of thiers.... plus size thickness of the ring. (crossing my fingers).
post #4 of 12 (permalink) Old 05-10-2008, 02:15 AM
I can get you the specs....just give me a few days. I need to get the guitar out of storage.
Jemmm is offline
post #5 of 12 (permalink) Old 05-10-2008, 03:08 AM Thread Starter
thanks I appreciate it, my original neck had been stolen so i had to put a 440p neck i had on it , so kinda still looking for a neck ,the 440 will have to do for now. whats a cool guitar like that doing in storage???? any pics?
post #6 of 12 (permalink) Old 05-10-2008, 04:10 PM
Why in storage? It's in mint condition. Many other cool guitar within close reach. Somehow don't want to ruin the virgin state of this one.
A non tripple 540p is still on my wish list. Something like this:
Jemmm is offline
post #7 of 12 (permalink) Old 05-13-2008, 06:51 AM
Threw this together in Autocad today. Did everything in mm, but that shouldn't give too much trouble for Dave.
Thickness of PU ring: 4mm. Phillips-head width of the 4 screws holding the ring is about 4mm. Drawing has straight corners but Dave will know how to round them properly so it looks like the real deal.
Hope this helps. Did see I forgot to mark the width of the PU-ring, should have been 58mm.
Taking it out of storage I was awestruck by the beauty of the instrument.
Jemmm is offline
post #8 of 12 (permalink) Old 05-13-2008, 09:18 AM
yep, great guitar indeed!
a couple more pics to help you. notice the rings is not "empty" inside, like a standard mould ring, but it's quite a thick, solid piece of plastic.
nuno is offline
post #9 of 12 (permalink) Old 05-15-2008, 09:10 AM Thread Starter
nice , thank you very much, if u ever sell her id like to be kept in mind , the body i got has some dings..... I hate to have to refinish but i think it might be the only way , know of anyone that does good work.....a fede swirl might be happening unless i can get the original paint color.nice axe.thanks
post #10 of 12 (permalink) Old 05-15-2008, 04:23 PM
I wouldn't worry so much about some battle scars. It only makes the guitar have more character. Unless it's really really bad, I wouldn't touch it.
And a swirl would simply ruin it. Wouldn't fit the guitar, and although there are some nice swirls out there, most of them are not.
For nice refinish you should check out Sims Custom Shop (banner on this site).
He has some nice refinish examples on his site. The custom mixed rosso red should come very close:
Or an LNG green 540p would be awesome too.
Jemmm is offline
post #11 of 12 (permalink) Old 09-26-2013, 07:00 AM
Hi there!
I'm bumping a five years old thread, but as this is a reference one...
Just to point out that the ring width cannot be 58mm, but around 66mm instead.
I believe that wrong 58mm width quoted resulted from any drawing mistake, then measuring on the drawing itself...
Cheers, JPB
IBZeP is offline
post #12 of 12 (permalink) Old 06-24-2014, 01:45 PM
Hi!
Finally here we have the corrected triple-coil pickup frame/ring template.
Thanks a lot to forum member nuno for providing some accurate dimensions and also for checking the final drawing against the actual ring itself
Enjoy, cheers, JPB
IBZeP is offline
custom shop , fede swirl , sims custom , sims custom shop
Pickguard template peter762033 Tech: Setup, Repairs and Mods 1 05-08-2008 10:50 PM
RG template for graphics The Euphor All Other Guitars (including Prestige) 7 04-15-2008 08:22 PM
Important Pickup Ring Question isida.d Pickups & wiring 2 10-22-2006 06:37 PM
Routing template or measurements for humbuckers stratoskier Pickups & wiring 9 12-18-2002 12:43 PM
Ring modulators - Ring modulators Fluke Gear, Equipment, Recording & Off Topic 0 02-12-2001 07:02 AM
