New rg350 going out of tune HELP! - Jemsite
post #1 of 34 (permalink) Old 03-09-2013, 11:13 AM Thread Starter
I bought a rg350dx 3 weeks ago, i made the set up myself from what i learned from here and from the instruction rich gave us at ibanez rulez, and i could rape the **** out of it when it had the factory strings and it would stay in tune, then i changed strings it was somehow worse it was going out of tune every hour or so and that if i wasnt abusing the tremolo. i changed again strings before 3 days and it was still the same. Yesterday i adjusted the action and the neck relief played for about half an hour after i did it and it was like before but today it goes out of tune every 10 minutes without doing anythink from yesterday and when i dive all the strigs are about 30-50 cents flat and when i pull the bridge up all string go about the same sharp. The guitar has the edze zero II and the string are 3 days old elixir 9-42 if there is something else you need to know so you can help me ask me i dont have money for a new bridge or a new guitar so i have to make this one playable again...
Mike_Thrash is offline
post #2 of 34 (permalink) Old 03-09-2013, 11:22 AM
Re: New rg350 going out of tune HELP!
Have you stretched the strings??
http://www.ibanezrules.com/tech/setup/stretch.htm
maqify is offline
post #3 of 34 (permalink) Old 03-09-2013, 11:34 AM Thread Starter
yep i have stretched them and if it was the strings it would probably be like this from the moment i changed them
post #4 of 34 (permalink) Old 03-09-2013, 02:45 PM
Reviews: 15
Are the nut pads nice and tight?
silverctr is offline
post #5 of 34 (permalink) Old 03-09-2013, 02:59 PM
Reviews: 13
^^This
Don't over do tighten them, ive seen many people destroy the thread in the nut due to over tightening, just nip them in place but make sure not to crush the strings.
RyansJem is offline
post #6 of 34 (permalink) Old 03-09-2013, 03:19 PM
Loose nut screws(back of the neck) will cause the guitar to go out of tune. Also good advice above-if nutpads is tighten to much they will eventually loose the ability to hold the string. And then the guitar will go out of tune.
maqify is offline
post #7 of 34 (permalink) Old 03-09-2013, 04:25 PM Thread Starter
the rg350 i have doesnt have any screws on the back of the neck it has it inside the nut and the are as tight as they came from the factory i checked them they were tight enough and even if this was the problem i dont think it would make all the string go flat when i dive and sharp when i pull up
post #8 of 34 (permalink) Old 03-09-2013, 04:34 PM
Ensure that the knife edges are at a right angle to the studs and adjust the springs oh so slightly.
Ibateur is offline
post #9 of 34 (permalink) Old 03-09-2013, 04:35 PM
Check this out:
http://www.ibanezrules.com/tech/setu..._stability.htm
maqify is offline
post #10 of 34 (permalink) Old 03-09-2013, 05:07 PM Thread Starter
i already have and i couldnt find the problem but i will check again tomorow
post #11 of 34 (permalink) Old 03-09-2013, 05:09 PM Thread Starter
if you mean the bridge should be parallel to the body it is
post #12 of 34 (permalink) Old 03-09-2013, 05:31 PM
Reviews: 15
Maybe lube the knife edges if they weren't already. I'm running out of ideas now.
post #13 of 34 (permalink) Old 03-09-2013, 05:47 PM Thread Starter
i want it to be the last think i have to do couse i changed string 3 days ago i dont want to throw away a new set of elixirs they are damn expensive xaxa anyway in greece we dont have chapsticks but we have liposan (like in many other countries to) i guess its somethink similar can i use it?
post #14 of 34 (permalink) Old 03-09-2013, 06:13 PM
Reviews: 120
Look at the instructions. You don't need to take the strings off to lube the knife edges.
LonePhantom is offline
post #15 of 34 (permalink) Old 03-09-2013, 06:16 PM Thread Starter
the instructions at ibanezrules?
edze zero 2 , out of tune , rg350dx
New RG350? Guitarmattms All Other Guitars (including Prestige) 6 06-05-2009 03:58 PM
Rg350 To buy or not to buy el-man All Other Guitars (including Prestige) 42 06-08-2007 04:07 PM
x2n in RG350 NickCormier All Other Guitars (including Prestige) 0 04-29-2006 07:10 AM
Wtb: Rg350 MilkshakeFiend Classified Ads: Guitars and Gear 0 03-08-2006 05:39 PM
tune up, lock down, tune up again? RSVampire Tech: Setup, Repairs and Mods 2 07-18-2003 03:34 AM
